The point I was making is that I don't like how the auto downshifts when it isn't necessary. The engine produces a lot of torque and could pull a high gear at low revs. I don't want to rev higher than I need to in urban areas.
There's other threads on the Forum about this (even one just recently which suggested that the manual said you shouldn't be running around at any speed/in any gear that let your revs drop below 3500 rpm!
That said, those '
Auto- Downshifts' weren't initially designed to make your life easier, they were included in the computer control of the Semi-automatic gearbox (which is actually still a 'manual gear box' tho, just with some sexy computer controlled 'quick-shift' features grafted onto it; along with the computer controlled clutch, which is actually also still a 'manual clutch' tho, and NOT a torque converter!!) as '
fail-safe down-shifts' to protect your Spyder from incompetent or forgetful riders who couldn't change down in time/appropriately, which are
triggered by the TCM to occur just above the minimum revs/speed/throttle/torque combination that would otherwise start causing some internal damage to your Spyder! Are you aware that back in the earlier years of Spyders, when the auto-downshift trigger
wasn't set at revs that were quite so 'high' and many people
did run around at lower revs, many discovered to their cost that real damage
DOES occur because they'd been just putting along at low revs/less than about 3000 rpm on their Spyders when they shoukdn't have been!!
So really, while that auto downshift
might be bothering you, it should actually be a learning experience, cos just like the Nanny/VSS et al telling you that you've pushed things too hard, those downshifts are the TCM/computers warning you that dropping your revs any lower in that gear at that speed
WILL be damaging things; so as far as BRP is likely concerned,
the 'auto-downshifts' set at that level ARE actually quite 'necessary' - well, at least until your warranty runs out anyway; when BRP will no longer have to pay to fix any damage you do; so then you can happily go ahead and destroy your Spyder's clutch &/or other components however you please, cos the necessary fixes will eventually be on your own dime!
Just Sayin'
