The Auto Downshift is irritating for changes to 2nd & 1st - can anything be done to block those down-shifts?
XB12X
This may have been discussed before, but I couldn't find anything. The auto downshift on my 2019, F3-S is irritating. It's okay down as far as 3rd gear, but changes down to 2nd and especially 1st when I don't want it to. Can anything be done about this in terms of blocking the last two downshifts? A gearbox that auto downshifted to 3rd, then not the bottom two gears would be perfect.
Trying to pull away from a stop sign in 3rd would not be pretty. Saw this happen with a very experienced HD trike driver. Getting it restarted while in traffic is hectic. Of course he has a manual clutch. Quit using the auto downshift anyway. Keep your rpms up just in case you need to get away fast in an emergency! Easier on you brakes also.
Can't change auto downshifts, maybe only in BUDS. That means your letting bike downshift at the minimum RPM level. Only option is to use paddle shifter to downshift sooner, don't know if that is your intention
The point I was making is that I don't like how the auto downshifts when it isn't necessary. The engine produces a lot of torque and could pull a high gear at low revs. I don't want to rev higher than I need to in urban areas.
It’s programmed to keep the engine from damage by lugging at too low RPM per gear. Anticipate or avoid those slow roads. Or get a Ryker & no shift
There's other threads on the Forum about this (even one just recently which suggested that the manual said you shouldn't be running around at any speed/in any gear that let your revs drop below 3500 rpm! :oops:)
That said, those 'Auto- Downshifts' weren't initially designed to make your life easier, they were included in the computer control of the Semi-automatic gearbox (which is actually still a 'manual gear box' tho, just with some sexy computer controlled 'quick-shift' features grafted onto it; along with the computer controlled clutch, which is actually also still a 'manual clutch' tho, and NOT a torque converter!!) as 'fail-safe down-shifts' to protect your Spyder from incompetent or forgetful riders who couldn't change down in time/appropriately, which are triggered by the TCM to occur just above the minimum revs/speed/throttle/torque combination that would otherwise start causing some internal damage to your Spyder! Are you aware that back in the earlier years of Spyders, when the auto-downshift trigger wasn't set at revs that were quite so 'high' and many people did run around at lower revs, many discovered to their cost that real damage DOES occur because they'd been just putting along at low revs/less than about 3000 rpm on their Spyders when they shoukdn't have been!! 😖
So really, while that auto downshift might be bothering you, it should actually be a learning experience, cos just like the Nanny/VSS et al telling you that you've pushed things too hard, those downshifts are the TCM/computers warning you that dropping your revs any lower in that gear at that speed WILL be damaging things; so as far as BRP is likely concerned, the 'auto-downshifts' set at that level ARE actually quite 'necessary' - well, at least until your warranty runs out anyway; when BRP will no longer have to pay to fix any damage you do; so then you can happily go ahead and destroy your Spyder's clutch &/or other components however you please, cos the necessary fixes will eventually be on your own dime! :sneaky:
Just Sayin' 😉
I have ridden getting on for 300,000 miles on two-wheeled motorcycles without damaging an engine or gearbox. The F3-S can run at lower revs than 3,500 rpm, just like all my high capacity two-wheelers could.
