Chupaca
Good luck..!!
Sadly the others will also rattle loose. I taped the holes and replaced them with bolts 5mm then those went and moved up to 6mm then gave up. Got to looking like a tailgunner the way the casing would twist and turn...
aluminum is too soft stick with the pop rivits (stainless) :banghead:
I have a Hindle, the rattles comes from the heat shield which is rivited, I too got pissed off with the rattle, I simply drilled the rivets out and voila no more heat shield or rattle, the Hindle now sounds like a real motorbike with cohonnes.
