Bracket made for SPYDERPOPS Missing Belt Guard
eddieshep999
I fitted the Spyderpops 'Missing Belt Guard' to my Spyder RT-S SE5 2010 Model
It offers great protection but it kept rubbing the outher wall of my tyre - Did try bending it but it seemed to always spring back
Did not want to use any heat to reshape it Just in case of fire (We all know Spyders are not to keen on fires)
Came up with a Stanless Steel U shaped bracket which attatches to the outside of original BRP belt guard - The bracket runs underneath the Spyder and the Spyderpop Missing Belt Guard fits inside the bracket
I used some foam between the Missing Belt Guard and the inside of my Bracket -
Different thickness will allow fine adjustments to be made where the Missing Belt Guard can be positioned
The spring in the Missing Belt Guard allows it to be held secure and away from the and the Drive Belt - The bracket can also be adjusted just by bending it in or out until you get the best positon away from the Tyre and the Drive belt
I have added some pictures in the Gallery - 'SPYDERPOPS BELT GUARD BRACKET '
http://www.spyderlovers.com/forums/album.php?albumid=2264
Here are some of the Pictures :-
SAM_0342 (640x480).jpgSAM_0343 (640x480).jpgSAM_0351 (480x640).jpgSAM_0348 (480x640).jpgSAM_0346 (480x640).jpgS
Some other Spyderpop Missing Belt Guard owners may find this useful
Eddie Sheppard
Reading UK
