PMK
Pop the Funklid, and let them see it... :2thumbs:
Also, an easy way to see inside when the little light is covered up...
All lights on as bright as you can get em during the day....make yourself seen:clap:
 Yet you should STILL be riding as if you're invisible! nojoke
  Yet you should STILL be riding as if you're invisible! nojokeIt even tells you to ride with your brights on in your Owners Manual.
next thing you'll tell me is I have to read the operator's card before I ride :doorag:
I've seen that with car headlights. I thought they were flashing lights until the car got closer and I saw they were not flashing. It doesn't take much of a bump up and down to make projector lights look like they're flashing.The appearance of the headlights flashing is caused the headlight angle change as the Spyder goes through the bumps. All vehicle headlamps do that. It just appears more dramatic in a projector style headlamp like used on a Spyder RT.
The same comment has been made with respect to a headlight modulator, which I use. My response to that is, "I'd much rather have you see me and be p***ed than not see me and run into me!" Of course it affects others. That's why it works.just that not everyone enjoys being distracted by someone that thinks his being noticed
does not effect others.
Ride safe and have a nice day.
Tip
Per the owner's manual:
Use your high beams whenever possible,
both day and night. Use low
beams to avoid blinding other motorists
at night or when too much light
reflects back, such as in fog.
RTFM!
I had to Google RTFM. :roflblack: That may be my new favorite acronym
