KX5062
Well-known member
My 14 RT has that same vibration and has had it from day 1. My theory is it is a combination of things. I think belt tension has something to do with it, but I think the bigger factor is the engine fuel management program in the ECM.
The EPA does some of their noise and emissions testing at certain engine RPM ranges, primarily around 4k or so, depending on the redline of that particular engine. As a consequence almost all motorcycle manufacturers have lean spots in that RPM range. Common wisdom is most fuel management programs are set so that they idle slightly lean, then get leaner from there until around the 4k RPM mark. Oddly enough, once you get near redline, the engine usually get very rich. That is done to protect the engine at very high RPMs, since no testing is done in that range.
