trikermutha
Starting to remind of the Harley again, putting on items that are not needed. Now I could understand a better tune but there is nothing out there yet for the 1330. :yikes:
Well, I'm just thinking of a nicer note on my Spyder. No, it's not needed.
(It's actually fairly low on my list)
Pam
What he said!
Works much better with the Big City Thunder baffle installed.
The back pressure improved the torque and mileage also.
Would you share a part number or specs, please?
I have the same tool, only mine is od green. Run it out the back a couple of feet, and have a helper pull it into place. Easy job. I have done a few. Go for it! If you get in trouble, call. JoePut the top spring on first...screwdriver. Then the bottom spring...spring puller. Here is a photo of my spring puller which is a piece of 550 cord.
I doubt that it's a design flaw. Remember; we're not supposed to be removing it anyway! :roflblack:
On post number 62,339 you stated the obvious, we're not supposed to remove them. I'm not sure why so many bother to go to the trouble and expense to remove the catalytic converter since it doesn't improve the performance or the gas mileage. On a personal note, I enjoy the sewing machine sound that allows me to enjoy my XM radio in my helmet. I know what exhaust sounds like and I prefer the sound of music.
This is considered a special applacition by Jim at Big City Thunder, give him a call he will take care of you. If you do a search on this site "Big City Thunder" you will find the post with picture of the baffle installed in the pipe.
I'm giving this mod some thought also.
What are the pros and cons?? Is the proformance increase worth the cost?? How about the noise increase?? Has Bob done this mod????
Ya know its either this mod or gun mods. Cost is simular.
Kaos
Devious56, had you ever considered changing your screen name, and it is a very cool screen name now, to Devious1
PK
Pam, I have a 2015 RT Limited, with some various mods, and at Biketoberfest this year, I had www.Spyder1attitude.com install his catalytic replacement pipe, and kept the stock Spyder muffler. It did not make it loud, but did give it a little sound. I can ride all day without any ill effects from noise, can hear my radio or gps with no problem. It seems to me to have made my performance a bit sharper, not head snapping, but a little better. It does reduce the heat as when you see your catalytic converter you will understand. And you loose about 20 pounds of usless weight. I wouldn't say mine Spyder backfires, or even pops and cracks, but woud describe it as a burble when decelerating. I don't know anything about the baffle that some folks are telling you that you need, Big Thunder, but when Schultzy installed mine I asked about reprograming the ECU and he said all you have to do after removing the Cat. is to idle your Spyder for 15 minutes and then shut it down and leave it sit for 15 minutes, and when you turn it back on, it will reprogram its self. It seems to have done that. I can't speak of gas mileage as my Spyder is new, and still breaking in, but, my mileage runs from 32 mpg to as high as 38 mpg depending on the type of gas and the octane rating, the best being real gas (non-ethanol) .
This is just my humble experience, and I feel that it is your ride, and you should be able to do what you want with it as long as you don't bother anyone else, This set up will not rattle windows, or wake people up, and I'd bet if you opened your house windows you wouldn't know when I rode past your house. It's a shame we aren't closer, I'd let you ride my Spyder and you could see for your self. You might give Spyder1Attitude call and talk to him, he is one of our sponsors and travels around to the get togethers installing his own brand of mufflers. He will install a cat delete pipe on your bike, let you ride it, and then take it off if you don't like it.
Good luck,
David
Pam
The cat bypass pipe by itself will do three things, change the exhaust note, reduce heat and cause you to lose midrange power do to loss of back pressure. By installing the Big City Thunder baffle at the front of the bypass pipe you add the back pressure back into the system where it needs to be mid pipe. Adding this Wii change the exhaust to a deaper sound and eliminate the dcell piping caused by a lean exhaust.
