Converting 6 pole WAGS trailer to 4 pole square Spyder
Blue3
Any guidance anyone can give about converting a 6 pole WAGS trailer to a 4 pole square Spyder will be greatly appreciated...
trailer wiring
Picking up trailer far from home. It has the amber turn signal lights. Could I take those wires to the respective 4-square and use them as both turn and brake lights and the red as only tail lights? I could change the lens to red which seems easier than re-wiring the trailer to separate the existing brake lights into turn/brake.
Thanks for all the help.
If you are in a time crunch maybe & only if you had informed escort to help :lecturef_smilie:
Just you & general traffic :yikes: No way, not me bud! I'd find another way to transport it!
Inside a truck bed or another trailer with good lighting :coffee: Getting it home & getting the lights right is better than being rear-ended from crazy light issues.
Any guidance anyone can give will be greatly appreciated
Check out Hopkins 47975 - 4 pin square. I had to connect a 4 pin round to my bike. Bought a standard 4 pin round and this Hopkins connect and made up a short connect between the Spyder and the trailer.
The trailer has amber turn signals. That means it is not a 4 wire system like the Spyder. But we still don't know if the trailer is actually a 6 wire or 5 wire system. Highly likely it's 5 wire. Then you need an electronic converter and build an adapter using that. Here is an example of one I found when I did a google search. https://www.etrailer.com/Accessories-and-Parts/Curt/C56196.html It separates the combined right and left brake/turn into right turn, left turn and brake.
Used trailer
Thank you. This appears to be the solution. One of the reviews was for a Spyder. Some reviews mentioned a diode, is this necessary? Thank you again.
There should be no need for any diodes on a trailer. Diodes would only be needed if your where towing a car.
I know this thread is almost 8 years old, but I just purchased a used Escapade Trailer with the 6 pole square plug, no brakes on the trailer but it has a cargo light in the trailer. I appreciate reading through this as I think the Curt box is the way to go to separate the signals for left, right, and brake. Thanks for the diode explanation as well.
My question is, does the 5 wire Spyder wiring harness carry 12v so I can keep the light, or is it a brake power connection?
I would say pull out the meter and see what you've got going there, write it down on a piece of paper and wire it up to the trailer, you may need a extra wire for the trailer light, but I don't know how long I would run that light without the motor running to keep a full charge on it! You may need to put a solar charger and a battery somewhere in the trailer to run on its own as an independent power source. :unsure:
