I'm just curious.
How do you get at the screw & rivet holding the middle panel on that is located underneath the top side panel?
Rear Side Panel Removal
1.
Remove middle side panel (one with grommets, where you check your oil).
2.
Remove top side panel:
2a.  Lift seat.
2b.  Remove lower wind deflectors.
2c.  Remove mirrors.
2e.  Remove upper retaining screws from top side panel.
2f.  Remove rear retaing screw from top side panel.
2g.  Remove service cover (under hood).
2h.  Remove lower (black) retaing screws of top side panel.
2i.  Remove top side panel by lifting it upward and freeing it from the two retaining grommets (under the silver security screws).
3.
Remove rear side panel:
3a.  Remove front retaining screw of rear side panel.
3b.  Remove upper retaining screw and washer from rear side panel.
3c.  Remove front plastic rivet from rear side panel.
3d.  Open side storage compartment (saddlebag) cover.
3e.  Remove rear retaining screws from rear side panel.
3f.  Remove top retaining screw from rear side panel.
3g.  Remove rear side panel from vehicle.
Bottom Rear Side Panel Removal
1.  Remove
middle side panel,
top side panel, and
rear side panel following steps above.
2.
Remove bottom front side panel:
2a. Remove upper retaining scre from panel.
2b.  Remove upper plastic rivet from panel.
2c.  From underneath panel, remove lower plastic rivets (push darts),
with care.
2d.  Remove bottom front side panel from vehicle.
3.  Remove bottom rear side panel:
3a.  Remove front plastic rivet from bottom rear side panel.
3b.  Remove retaining screws from bottom rear side panel.
3c.  Remove bottom rear side panel from vehicle.
These procedures are in your Owner's Guide...with pictures.
