BertRemington
Based on your symptoms so far (was working, no change when flasher disconnected) the most likely cause is a sticking brake switch as noted above. The switch is an SPST N-O microswitch which provides +12V to both the ECM and the brake lights. The brake lights (and taillights) are LEDs so respond instantly to the +12V. Any flicker in the brake lights is also observed by the ECM. If the ECM has debounce logic I doubt it's longer than 50ms.
Best wishes.
Best wishes.
