DESS error may be due to all the aftermarket electronic add-ons? Just throwing it out there!
Cloak
2014 Spyder RTL… recently started getting the DESS error no start condition. But it only seemed to happen after the first initial start of the day. Would start great in the morning but after that, error! I started thinking, maybe it’s because of all the aftermarket electronic shit I’ve added (LEDs, 2400 watt amp, aftermarket GPS, a couple of USB charging ports, roar pedal) so I decided to just do a reset (disconnected battery for a few minutes) and so far no more error. I also removed my key from an aftermarket holder just in case it was interference causing the error. 800 miles later, still starts with no error.
I’m not saying I fixed my issue permanently (yet) just throwing it out there for anyone experiencing that error before they trailer their machine to the stealership!
There are a few threads on this subject if you're interested in reading, do a search! Happy reading! If it's the last time you see this error, you'll be lucky!
After previously reading through all the DESS threads here regarding DESS... seeing the dreaded DESS appearing ONCE is enough to make you concerned, IMO.
I had the DESS show its ugly self a couple times. That was 2 too many times for me. I had hooked up with another Spyder member here and had my DESS disabled, like many others who have done here. Best thing I could have ever done for peace of mind and not being DESS stranded.
Glad that your DESS hasn't shown its ugly face since. But beware, if it ever does again, I would definitely be seeking someone to disable it. JMO, of course.
Turned mine off on my 2014... don't want to be 1000+ miles from home and have that error staring at me, requiring a trailer ride to God knows where a competent Spyder dealer might be from me. It is worth the peace of mind to me not to have to chance it with that known issue. And... it is nice have some inexpensive cut keys that will run the bike, including one tucked in my wallet ... just in case.
"Peace of mind", my sentinments exactly.
Having that DESS issue makes you not want to travel too far from home for fear of being stranded ANYWHERE. I also made it a point to purchase a Jump Pak, for that just in case moment the battery suddenly decides not to crank . A little extra security assurance.
Good Evening Cloak,
I started a Thread on Aug. 13, 2015 about this - The name of the thread is: DESS KEY CODE AGAIN!!!!!!!!!!!!!!!!.
Please read Post # 1,100 on page 55 (last post) it is posted by Peter Aawen, he is a moderator on this site. That thread is Closed per Peter Aawen; also, that thread has a lot of very useful information about the DESS Error.
Deanna
A buddy of mine has the BUDS diag tool and he’s going to disable the DESS for me. Luckily, since I removed my key from the holder it was in and reset the system via battery disconnect, I haven’t had the error come back.
Thanks everyone.
Make sure he has Megatech license level... just BUDS Diagnostics doesn't have the DESS Disable permission. BUDS Diagnostics will only allow additional keys to be added to the DESS system. I have had the Megatech licensing for 10 years for this vintage of Can Am product line, and disabling DESS was straight forward. I will be on a 4k tour shortly and it's nice to know that won't be able to strand me. Good luck not seeing that error again.
I’m not sure which license he has has but I will check.
Can Am should make it possible to disable the DESS (along with other changes / settings) without needing their scantool. Should be able to do it in the settings somewhere or maybe a secret menu
That's the hard thing... without BUDS, you can't do much other than retrieve codes... and BUDS is an expensive purchase. But if you do your own work, it does eventually pay to have it (if you are not near someone with it).
