The question with some of the SE5 problems is...are they actually getting it right? So much electronics...argh!
There is problems with the SE5? :dontknow:
Hi to all SpyderLovers,
This is my first time to attempt a thread so a little patience is appreciated,
I, like so it seems many others have the same sort of problems with the transmission.
When I first pick my S/B 08 SE5 I had all sorts of warnings flashing across the display, Check DPS, Temp gauge reading about 10 degrees higher, oil light flashing on most of the time, and starting an intermittent problem. When I had a look around the machine I found that none of the battery leads where tightened up. This only solved the DPS waring and made it easier to steer at lower speeds. With the transmission it wants to throw me out of the saddle sometimes when it’s changing down, and making a very harsh dry noise through all gears, also considerable vibration.
I had a test ride on the demo bike it was smooth and in changing down automatically had a little blip of power and changed smoothly, mine is like someone trying to break out with a sledge hammer. After this ride it was a must have. Not so sure Now.
With taking it back to the dealer and having it test ridden, diagnostically checked they said it was fine, with a tweak of something here and there(DUR, it’s not). But when I went to leave “in disgust” it wouldn’t start, in showing the mechanic this he decided to replace the selector switch for the transmission. I am still waiting for it to be acquired and fitted. Has anyone experienced the very disappointing start that I am having?
Ok enough belly aching for now, I love the concept of the Spyder, but I would just like a smoother ride.
SpyderLover TonyF.
Yes I am destined to join the line of depressed SE5 owners. My SE5 has 1200Km and I can't even ride it to the store because it locks up in 1st gear. The remedy is quite simple, I pull the 5 amp fuse from the the fuse panel, put it straight back in and everything works, for a while, I have spoken with my dealer twice (who are 300 Km away) and they are trying to sort somthing.
Me and 8 friends went for a ride tonight, I was too embarrassed to take the spyder so I rode my son's Harley instead.
Good job BRP, I now have a $22,000 piece of junk in my garage.
:roflblack:There is problems with the SE5? :dontknow:
This is does not effect every SE but it is a fix for some of them for sure.Yes I am destined to join the line of depressed SE5 owners. My SE5 has 1200Km and I can't even ride it to the store because it locks up in 1st gear. The remedy is quite simple, I pull the 5 amp fuse from the the fuse panel, put it straight back in and everything works, for a while, I have spoken with my dealer twice (who are 300 Km away) and they are trying to sort somthing.
What is your Spyder doing?I am in the same boat, Just started having shifting problems at 2000 miles. I have a 2009 SE5, has been in the shop since 4/15/09. Starting to get a little dissapointing, but I am at the mercy of BRP and their service techs. It's kinda like this ( if this doesn't work, we will send you this part to fix it,,, no fix,, OK we will send you this part to fix it,,, no fix,) sooner or later they are going to run out of parts to replace to try and fix. Getting very close to giving up, after 2 months of riding and my bike being in the shop for almost 3 weeks. Not too much fun...
	Back to the shop in the morning, 27/05/09 to have the starting problem looked at, no joy whatsoever with the downshift, after having the sensor changed.:gaah:Hi to all SpyderLovers,
When I first picked up my S/B 08 SE5 I had all sorts of warnings flashing across the display, Check DPS, Temp gauge reading about 10 degrees higher, oil light flashing on most of the time, and starting an intermittent problem. When I had a look around the machine I found that none of the battery leads where tightened up. This only solved the DPS warning and made it easier to steer at lower speeds. With the transmission it wants to throw me out of the saddle sometimes when it’s changing down, and making a very harsh dry noise through all gears, also considerable vibration.
SpyderLover TonyF.
