Do you Need better brakes coz stock discs are twisted?
I am on my 5th RT Ltd since 2011 and never had an issue pulling a RT622 trailer on the 2011, 2014, and 2016. I've never had a brake disc problem either, but the 2020 and 2023 have cost me 6 sets of discs. I brake using engine compression like crazy but that can't always be enough, and only once did I have to use heavy braking!!! So in my book, the quality since 2020 really took a dive for the worst, probably made in China Brembo. I have just received my new floating disc brake from Martin and sure hope these good looking discs will do the trick!🤞
In all of those brake jobs you have done, were they all stock pads and rotors you replaced them with? Have you ever tried EBC?
2 year old thread revived! My 2020 RT had a warped right rotor after 1 year and 15k miles of spirited riding. I replaced both front rotors with EBC and only use EBC pads (incl. on all bikes since 2010). Replaced the EBC pads at 36k and have 44k trouble-free miles so far. YMMV.
Old thread... Current issue.
Had a customer with an F3 that went through 3 OEM rotors. Warranty covered them all. (I applaud the dealership for this level of service. Many will tell you that the rotor is considered a wear component and not covered). Anyway, with the 4th warped rotor he came to us for EBC replacements because the warranty had expired and it was on his dime this time.
He never had another warped rotor. We've had similar encounters, but none as drastic as this one. We have a number of customers convert the front rotors and pads just to get improved stopping power. It is great to be able to recommend something proven to work well.
My 2024 RT STS had a surprising 71 km when I got it new. Yes, my bill of sale says 0 Km’s, and the discs where warped… I have not gone back to that dealer since, they will never get my money again…
Anyway, I changed the discs and pads, but then when on a group ride 2 up with trailer and very spirited driving… yep, I warped that set as well; and I warped a third set. Pretty much the same thing happened, only this time I didn’t have much mileage on the new set and warped only one side.
So I got a set of floating discs from Martin and I will install those in the Spring when the bike comes out of the second garage (there's snow here) and do a proper break-in this time. I’m no longer 2 up, got the wife an F3…
Hopefully this set will be it. We do lot of mileage, I purchased it Aug 2024 and I've already got 30,000 Km’s
The first set were stamped Brembo; the other 2 sets were EBC, with EBC Pads…
That's impressive that you were able to warp a set of EBC rotors. Any rotor can be warped, of course. Some just require more effort. Did you go through the bedding in process? Were you torquing in at least 2 steps to the correct value? Were you, by chance, sitting stopped, applying pressure on the brake pedal with very hot rotors and pads?
Hello From Queensland Australia, I originally had a complete OEM setup with a Handbrake kit from ICSI due to MS as I am unable to use my right foot, I actually found that just stopping in time I really had to read the traffic conditions as my hand is nothing like stomping on my brake pedal with a size 13 foot and as the brakes got older I had to continually adjust how I rode and even going through 2 sets of OEM pads since I had the bike, I then started reading all I could on brakes and decided to use Martins offering with his rotors and EBC pads, all I can say is WOW, what difference.
I am now tempted to try his rear rotor now as the front alone by themselves made a huge difference.
Yes, I went through the bedding process, but like I said, we had a trips with the trailer and it was cut short (both times). I’m an Old Aircraft technician, so yes, everything is done as per the manual and normal practices (torques, etc, and ton’s of tools that I know how to use)
I don’t think I have the brakes ON with very hot disks, but maybe don’t remember that… the last set only one is twisted just a tiny bit… so both would be I guess if that was the case…
Anyway, I been riding sport bikes like Ducati's since the 70’s and never had to change a disk… I don’t blame anything, it is what it is.
Not looking to lay blame. Just very curious as to what the cause might be. Pulling a trailer does put more heat on the brakes. Surprisingly, though, we have seen very few warped brakes with those who pull trailers. You would think riding 2-up and a trailer, that would do it. I assume that these people ride more conservatively because of the trailer.
One of our OEM rotors warped pretty shortly after we got our Spyder, so I converted the fronts to EBC last spring before a big trip. We pulled a trailer around Lake Erie with lots of fun stops along the way. The brakes saved our a$$es one evening at dusk when two deer jumped out of a ditch along a 2 lanes rural road and ran across in front of us. I slammed the brake pedal and we stopped on a dime. It was very impressive how the nose of the bike dove down, my wife lifted slightly out of her seat and the trailer stayed squarely in line. No slipping or sliding, just one very aggressive and impressive stop.
