shakin_jake
Is this the engine drain bolt? If so, is it an Allen or? & what size? Looks like an Allen to me TIA
I’m guessing this is the clutch drain plug? Again, what type of fastener is this, Allen or (can’t remember what they’re referred to) ?…and what size please, if you know
2021 Spyder RT Limited. What a bugger of a time I’m having<LOL>. My 2020 Ryker Rally was so much easier to change engine fluid, at least to drain
While I have your collective ears, what are others using to get this beast up in the air for a simple (LOL) oil change? I’m using car ramps on the front wheels. I’m thinking jack stands would be easier. Where are you jacking, and placing the stands if you’re doing it that way. Admittedly, the jack stands I have are in bad shape. Haven’t used them in years, they’re a bit rusted & primarily why I’m using ramps
Cretin Girl in all her glory. FWIW I turned over 3K miles this morning running an errand. Baja Ron’s oil change kit came in the mail yesterday? So, thought I’d do the oil change now while the motor oil is hot
Best,
Jake
Reddick Fla.
Life is beautiful
