BajaRon
Well-known member
Perhaps so, but my first Spyder, a 2010 model (which, by the way, handled like a dead pig until you came out with your sway bar upgrade) had the clutch plates go with only 10,000 miles in less than a year.
BRP didn't want to replace the clutch plates under warranty, saying that the clutch was a wear item and this was normal wear for a big bike. I'd had several big bikes prior to my Spyder with no clutch problems at all. I still miss my 1984 Yamaha Venture Royal XVZ12.
I replied, so let me understand, the clutch wears out before the brakes? At that point BRP was kind enough to replace the clutch plates.
Again, I ask why tempt fate if you don't need to.
Of course when braking for long periods of time, such as going downhill, engine braking is best. But in daily traffic?
We all have our little quirks, and that's mine.
I stand by my comments but have no need for anyone to copy my style or preferences. To each, their own.
You say potato, I say potato....................
The Spyder clutch (998 & 1330) will normally last the life of the machine if used as designed. Unfortunately, especially with the SE models, the clutch will not last very long at all if 'abused'. Now, of course, most do not purposefully abuse their clutch, though we do have a customer or 2 that do. Here is my opinion (which is worth what it will cost you) on the 'Whys'. But engine braking isn't going to be one of them since this exerts much less stress on the clutch than acceleration. And it will always be done at higher RPM's giving you full clutch plate lockup. It's slipping that ruins a clutch. Once it's locked up, which happens right away in engine braking, the clutch doesn't care at all.
#1 - On an SE model, running too low RPM. People do this for a number of reasons. They came off a machine where high RPM was detrimental. Or they don't like the sound of a higher revving engine because 'It sounds like it's hurting the machine'. But the Spyder needs to maintain about 3,500 RPM to fully couple the clutch plates under load (SE models only). This is not a hard and fast rule. But if you don't know the nuances, just keep your upshifts to at least 3,500 RPM when you land in the new gear. Obviously, engine braking, done reasonably, will not damage your clutch plates. An SM model clutch does not care about RPM because it fully engages as soon as you fully release the clutch lever.
#2 - Using the wrong oil. This will destroy a clutch even more quickly than running an SE at too low an RPM. This will damage a clutch in both the SE and SM. Many people stick with the OEM oil because they are worried about getting the wrong oil. But it's very easy to get a better, less expensive or equally priced engine oil with zero worries about creating this issue. Just get a full synthetic 5/40, 10/40 or 15/40 that is JASO MA2 rated. It's as simple as that. There are oils that meet the JASO MA2 rating but have chosen not to spend the money to get certified. You need to be careful here. But if you do your homework, this can also be a viable option. I've had some customers say they've used OIL A in their various motorcycles for years without issue and they plan to do the same with their Spyder. Don't do it unless the oil you've been using meets the above criteria. Don't find out the hard way that you used the wrong engine lubricant.
#3 - I have a few customers who really flog their Spyder (manual transmission). I'm not sure exactly how they are using the clutch, but they have managed to burn them up. I've drag raced my 2008 998 several times with no clutch damage so I'm not sure what the difference is. But I suspect they are using the clutch to shift. You should use a clutchless shift if you are drag racing. But be careful. Done wrong, a clutchless shift can give you a great deal of grief. Fortunately, it's not a difficult maneuver to master.
Observe these things and you'll never get a complaint from your clutch. This is why BRP didn't want to replace your clutch. In most cases, the failure was caused by improper usage of some kind.
