DPS code and limp home code after installing a juicebox
			Hoping someone can help me out with this maybe to help reset it or figure out why it was working great when i installed the exaust but after installing juicebox pro two codes came up the DPS and VSS fault and check engine light comes up as soon as i turn the key but not started.So might sound like a silly question the white/brown stripe from the (tps) that i cut i used the one end to attach to the grey wire from the juicebox... was i suppose to attach the other end or is that just a dead end wire after its cut? it doesnt clarify on where that wire was suppose to go.. Anxiously awaiting a response
		 And another question on the juicebox itself what color is the status light suppose to be? right now i have a mild red light.thanx... Sean
