Peteoz
Well-known member
I know I have asked this before, but maybe someone has stumbled on it by now.
On the Euro/Aus models, the low beam headlights are located where the US riders install their "fog" lights via a plug and play connector to a pre wired switch alongside the heated grips switch.
On the Euro/Aus models, we have the pre-wired switch (sort of.....the wiring goes into a black blank cover plate). It has an orange/red wire, a grey/yellow(although the yellow could possibly be a pale green or beige) wire and two black earth wires.......
Does anyone know where these coloured wires terminate? I am trying to find the "other end" if it is not in use, so I can use the switch to wire in a couple of Tricled spot lights off the front wheels. It also has to be linked to the high beam wiring so they can only come on when high beam is operational, but that's another task.
If I can't find the other end (I tried following the wiring diagram, but my head started hurting :gaah
, I'll just move the current blank switch and run new wiring from the spot lights direct to the soon to be purchased switch.
I just reread the above and can hardly understand it myself:hun:, so I'll understand completely if I get no responses :shocked:
