major911
DOES NOT WORK WITH BRP TALL BOY BRACKETS
(If you are not sure what BRP Shield you have, Measure bolt pattern, 3.5" center to center is correct for Freedom shield)
Will NOT fit the standard F3/F3-S
When we first saw this shield on a F3T, we knew it was a winner. This shield looks better than stock and gives you better wind protection than stock, without looking out of place or oversized. Freedom shields for the Can-Am Spyder are a LAMONSTER GARAGE exclusive, everyone comments on what a great looking shield it is. The polished edges, and precise fit really show the pride FREEDOM takes in its products. You'll stand out in a crowd with a FREEDOM windshield.
Windshield size, Your stock windshield is 12" so if you measure up from the bottom center of your stock shield 17" that will give you the height you would have with this shield.
This windshield comes with a bottle of Lamonster Garage Black Dymond Detailer LG-5011 with commercial grade microfiber cloth to keep your windshield bug free and clean. I also supplied are 4 stainless replacement washers with a rubber backing that holds up much better than the stock washers.
Material:
Premium high impact modified acrylic - very durable - (same material used around hockey rinks)
D.O.T. Approved - Exceeds industry and D.O.T. standards
UV protection - shield will not discolor or haze from the sun or weather
$175.00 (plus shipping)
Material:
