BRP took quick action with my ST overheating...
I have posted my overheating experience with the Dealership & BRP in another thread, but to sum it up, my 2013 ST Ltd was overheating, going into limp mode, and throwing code P0217 4. Dealer called BRP and BRP said to replace the temperature sensor, radiator, and thermostat. Furthermore, BRP asked that the parts be sent back to them for inspection. I then received a phone call from BRP (Canada # on caller ID) asking if I was satisfied with the way my repairs were being handled by both the dealership and BRP. I was blown away by all of these actions as they seem to be the antithesis of the sentiments expressed in this thread. It seems as if my experiences with BRP as a Spyder owner have been an anomaly. I have been happy with the service, repairs, and follow up thus far. I'm not saying that my ride hasn't been in the shop a lot in the 2 months since i've owned her (6 visits) BUT, i've always received a loaner and the repairs have never been over 2 days in length thus far. I am not defending BRP nor am I leading the charge against them...i'm just sharing my experience with them thus far. Below are both repair orders for the overheating experienced...
REPAIR #1:
[TABLE="width: 100%"]
[TR]
[TD][TABLE="width: 100%"]
[TR]
[TD]
REPAIR ORDER INVOICE # 8477[/TD]
[TD]
Elk Grove Power Sports
10491 East Stockton Blvd Suite A
Elk Grove, CA 95624
(916) 714-7223[/TD]
[TD][/TD]
[/TR]
[TR]
[TD]
Sold To :
Tony XXXXX
XXXXXXXXX
Fair Oaks, CA 95628
(M) (916) XXX-XXXX [/TD]
[TD][/TD]
[TR]
[TD]
In Date: [/TD]
[TD]
Jul.23, 2013 [/TD]
[/TR]
[TR]
[TD]
P/U Date: [/TD]
[TD]
Jul.25, 2013 [/TD]
[/TR]
[TR]
[TD]
Service Writer: [/TD]
[TD]
FPercy [/TD]
[/TR]
[/TABLE]
[/TD]
[/TR]
[/TABLE]
[/TD]
[/TR]
[TR]
[TD][/TD]
[/TR]
[TR]
[TR]
[TD]
Make [/TD]
[TD]
Model [/TD]
[TD]
Year [/TD]
[TD]
Vin Number [/TD]
[TD]
Engine Number [/TD]
[TD]
Key Board [/TD]
[TD]
Miles/Hours [/TD]
[/TR]
[TR]
[TD]Can-am [/TD]
[TD]SPYDER ST LIMITED SE5 [/TD]
[TD]2013 [/TD]
[TD][/TD]
[TD][/TD]
[TD]N/A [/TD]
[TD]1130.00 [/TD]
[/TR]
[/TABLE]
[TR]
[TD]
Job: Job 1 Inspect and advise customer states vehicle is running hot.[/TD]
[/TR]
[TR]
[TD][/TD]
[/TR]
[TR]
[TD]
Job Description:
Perform inspection and advise customer states vehicle is running hot. Found fault P0217 4 count 33 hours. Engine coolant overtemp. The coolant level is correct. Could not duplicate the problem. The unit idled for over a half hour cycling the fan between 217 and 203. Talked to Perry at BRP. Call ID # 4158754. He said since the fault occurred in first gear, it sounds like an air flow issue or possibly the radiator.[/TD]
[/TR]
[TR]
[TD][/TD]
[/TR]
[TR]
[TD]
Resolution:
Replaced the engine temp sensor. Test rode for machine for 48 miles operates properly at his time with no faults.[/TD]
[/TR]
[TR]
[TD][/TD]
[/TR]
[TR]
[TD]
Recommended Repairs:[/TD]
[/TR]
[TR]
[TD][/TD]
[/TR]
[TR]
[TD][TABLE="width: 100%, align: right"]
[TR]
[TD]
Technician [/TD]
[TD]
Job Description [/TD]
[TD][/TD]
[TD]
Hours [/TD]
[TD]
Rate [/TD]
[TD]
Discount [/TD]
[TD]
Labor Total [/TD]
[/TR]
[TR]
[TD]Bcrawford [/TD]
[TD]Job 1 Inspect and advise customer states vehicle is running hot. [/TD]
[TD][/TD]
[TD]Warranty [/TD]
[TD]0.00 [/TD]
[TD]0.00 % [/TD]
[TD]$0.00 [/TD]
[/TR]
[/TABLE]
[/TD]
[/TR]
[TR]
[TR]
[TD]
Part Number [/TD]
[TD]
Description [/TD]
[TD]
Qty [/TD]
[TD]
Price [/TD]
[TD]
Unit Extension [/TD]
[TD]
Extension [/TD]
[/TR]
[TR]
[TD]420274040 [/TD]
[TD]SENSEUR.*TEMPERATURE SENSOR [/TD]
[TD]1 [/TD]
[TD]$0.00 [/TD]
[TD]$0.00 [/TD]
[TD]$0.00 [/TD]
[/TR]
[TR]
[TD]219700362 [/TD]
[TD]ANTIFREEZE [/TD]
[TD]1 [/TD]
[TD]$0.00 [/TD]
[TD]$0.00 [/TD]
[TD]$0.00 [/TD]
[/TR]
[/TABLE]
[/TD]
[/TR]
[TR]
[TD][/TD]
[/TR]
[TR]
[TD][/TD]
[/TR]
[TR]
[TR]
[TR]
[TD]
Labor: [/TD]
[TD] $0.00 [/TD]
[/TR]
[/TABLE]
[/TD]
[/TR]
[TR]
[TR]
[TD]
Parts: [/TD]
[TD] $0.00 [/TD]
[/TR]
[/TABLE]
[/TD]
[/TR]
[TR]
[TR]
[TD]
Fees: [/TD]
[TD] $0.00 [/TD]
[/TR]
[/TABLE]
[/TD]
[/TR]
[TR]
[TR]
[TD]
Sublet: [/TD]
[TD] $0.00 [/TD]
[/TR]
[/TABLE]
[/TD]
[/TR]
[TR]
[TR]
[TD]
Sub Total: [/TD]
[TD] $0.00 [/TD]
[/TR]
[/TABLE]
[/TD]
[/TR]
[TR]
[TR]
[TD]
Tax : [/TD]
[TD] $0.00 [/TD]
[/TR]
[/TABLE]
[/TD]
[/TR]
[TR]
[TR]
[TD]
Job Job 1 Inspect and advise customer states vehicle is running hot. Total: [/TD]
[TD] $0.00 [/TD]
[/TR]
[/TABLE]
[/TD]
[/TR]
[TR]
[TR]
[TD][/TD]
[/TR]
[/TABLE]
[/TD]
[/TR]
[/TABLE]
[/TD]
[/TR]
[TR]
[TD]
Job: Job 2 Perform bleeding of coolant system[/TD]
[/TR]
[TR]
[TD][/TD]
[/TR]
[TR]
[TD]
Job Description:
Performed coolant replacement procedure to specifications. With the miles on it, there shouldn't be any air in the system. BRP had a spyder specialist call. Spoke too Davey Call ID# 4168971. He said to check to see if the thermostat was upside down. It is installed correctly. He also said that the new spyder panels are holding in more heat. They have had issues with customers riding their unit at slow speeds. Stopping for a short period of time with the engine off. Then when they restart the unit the coolant is over heating. They then take off and it cools back down.[/TD]
[/TR]
[TR]
[TD][/TD]
[/TR]
[TR]
[TD]
Resolution:
Call ID# 4168971. It is installed correctly. Performed coolant replacement procedure to specifications.[/TD]
[/TR]
[TR]
[TD][/TD]
[/TR]
[TR]
[TD]
N/A [/TD]
[/TR]
[TR]
[TD][/TD]
[/TR]
[TR]
[TR]
[TD]
Technician [/TD]
[TD]
[TD][/TD]
[TD]
Hours [/TD]
[TD]
Rate [/TD]
[TD]
Discount [/TD]
[TD]
Labor Total [/TD]
[/TR]
[TR]
[TD]Bcrawford [/TD]
[TD]Job 2 Perform bleeding of coolant system [/TD]
[TD][/TD]
[TD]Warranty [/TD]
[TD]0.00 [/TD]
[TD]0.00 % [/TD]
[TD]$0.00 [/TD]
[/TR]
[/TABLE]
[/TD]
[/TR]
[TR]
[TD][/TD]
[/TR]
[TR]
[TD][/TD]
[/TR]
[TR]
[TD][/TD]
[/TR]
[TR]
[TR]
[TR]
[TD]
Labor: [/TD]
[TD] $0.00 [/TD]
[/TR]
[/TABLE]
[/TD]
[/TR]
[TR]
[TR]
[TD]
Parts: [/TD]
[TD] $0.00 [/TD]
[/TR]
[/TABLE]
[/TD]
[/TR]
[TR]
[TR]
[TD]
Fees: [/TD]
[TD] $0.00 [/TD]
[/TR]
[/TABLE]
[/TD]
[/TR]
[TR]
[TR]
[TD]
Sublet: [/TD]
[TD] $0.00 [/TD]
[/TR]
[/TABLE]
[/TD]
[/TR]
[TR]
[TR]
[TD]
Sub Total: [/TD]
[TD] $0.00 [/TD]
[/TR]
[/TABLE]
[/TD]
[/TR]
[TR]
[TR]
[TD]
Tax : [/TD]
[TD] $0.00 [/TD]
[/TR]
[/TABLE]
[/TD]
[/TR]
[TR]
[TR]
[TD]
Job Job 2 Perform bleeding of coolant system Total: [/TD]
[TD] $0.00 [/TD]
[/TR]
[/TABLE]
[/TD]
[/TR]
[TR]
[TR]
[TD][/TD]
[/TR]
[/TABLE]
[/TD]
[/TR]
[/TABLE]
[/TD]
[/TR]
[/TABLE]
[/TD]
[/TR]
[TR]
[TR]
[TD]
[/TD]
[TR]
[TR]
[TD]
Labor: [/TD]
[TD] $0.00 [/TD]
[/TR]
[/TABLE]
[/TD]
[/TR]
[TR]
[TR]
[TD]
Parts: [/TD]
[TD] $0.00 [/TD]
[/TR]
[/TABLE]
[/TD]
[/TR]
[TR]
[TR]
[TD]
Fees: [/TD]
[TD] $0.00 [/TD]
[/TR]
[/TABLE]
[/TD]
[/TR]
[TR]
[TR]
[TD]
Sublet: [/TD]
[TD] $0.00 [/TD]
[/TR]
[/TABLE]
[/TD]
[/TR]
[TR]
[TR]
[TD]
Sub Total: [/TD]
[TD] $0.00 [/TD]
[/TR]
[/TABLE]
[/TD]
[/TR]
[TR]
[TR]
[TD]
Tax : [/TD]
[TD] $0.00 [/TD]
[/TR]
[/TABLE]
[/TD]
[/TR]
[TR]
[TD][/TD]
[/TR]
[TR]
[TR]
[TD]
Total: [/TD]
[TD] $0.00 [/TD]
[/TR]
[/TABLE]
[/TD]
[/TR]
[TR]
[TR]
[TD][/TD]
[/TR]
[/TABLE]
[/TD]
[/TR]
[TR]
[TR]
[TD]
Balance: [/TD]
[TD] Warranty [/TD]
[/TR]
[/TABLE]
[/TD]
[/TR]
[/TABLE]
[/TD]
[/TR]
[/TABLE]
[/TD]
[/TR]
[TR]
[TD][/TD]
[/TR]
[TR]
[TD][/TD]
[/TR]
[TR]
[TD]A six month craftsmanship only warranty applies to all repairs. Part failure warranty is the responsibility of the part manufacture, should a warranty exist. Due to space limitations we ask that all vehicles are picked up within 72 hours of repair completion. Failure to pickup the unit within the above time frame can result in a $35.00 per day storage fee. Please inform the your Service Advisor if you would like parts returned. Old parts will be disposed of once the vehicle has left the possession of Elk Grove Power Sports unless specified by customer to return.
BAR # ARD00261580
REPAIR #2:
[TR]
[TR]
[TD]
REPAIR ORDER INVOICE # 8507[/TD]
[TD]
Elk Grove, CA 95624
(916) 714-7223[/TD]
[TD][/TD]
[/TR]
[TR]
[TD]
Sold To :
Tony XXXX
XXXXXXXX
Fair Oaks, CA 95628
(M) (916) XXX-XXXX[/TD]
[TD][/TD]
[TR]
[TD]In Date:[/TD]
[TD] Jul.26, 2013[/TD]
[/TR]
[TR]
[TD]P/U Date: [/TD]
[TD] Aug.07, 2013[/TD]
[/TR]
[TR]
[TD]Service Writer:[/TD]
[TD] FPercy [/TD]
[/TR]
[/TABLE]
[/TD]
[/TR]
[/TABLE]
[/TD]
[/TR]
[TR]
[TD][/TD]
[/TR]
[TR]
[TR]
[TD]
Make [/TD]
[TD]
Model [/TD]
[TD]
Year [/TD]
[TD]
Vin Number [/TD]
[TD]
Engine Number [/TD]
[TD]
Key Board [/TD]
[TD]
Miles/Hours [/TD]
[/TR]
[TR]
[TD]Can-am[/TD]
[TD]SPYDER ST LIMITED SE5[/TD]
[TD]2013[/TD]
[TD][/TD]
[TD][/TD]
[TD]N/A[/TD]
[TD]1595.00[/TD]
[/TR]
[/TABLE]
[TR]
[TD]
Job: Job 1 Perfrom replacement of radiator[/TD]
[/TR]
[TR]
[TD][/TD]
[/TR]
[TR]
[TD]
Job Description:
Perfrom replacement of radiator and thermostats. There were no faults on Buds this time when the unit was picked up from customer.[/TD]
[/TR]
[TR]
[TD][/TD]
[/TR]
[TR]
[TD]
Resolution:
Call ID# 4158754.Job code 01 46. .6 hours. Replaced the thermostat. Job code 01 19. .8 hours. Mike Carter called back and told us to replace the radiator. Replaced the radiator. Replaced the thermostat. Rode the unit 10 miles. Let idle. The fan cycled properly and the coolant is at the proper level. There still were no faults at this time.[/TD]
[/TR]
[TR]
[TD][/TD]
[/TR]
[TR]
[TD]
[/TR]
[TR]
[TD][/TD]
[/TR]
[TR]
[TR]
[TD]
Technician [/TD]
[TD]
[TD][/TD]
[TD]
Hours [/TD]
[TD]
Rate [/TD]
[TD]
Discount [/TD]
[TD]
Labor Total [/TD]
[/TR]
[TR]
[TD]Bcrawford[/TD]
[TD]Job 1 Perfrom replacement of radiator [/TD]
[TD][/TD]
[TD]Warranty [/TD]
[TD]0.00 [/TD]
[TD]0.00 % [/TD]
[TD]$0.00 [/TD]
[/TR]
[/TABLE]
[/TD]
[/TR]
[TR]
[TR]
[TD]
Part Number [/TD]
[TD]
Description [/TD]
[TD]
Qty [/TD]
[TD]
Price [/TD]
[TD]
[TD]
Extension [/TD]
[/TR]
[TR]
[TD]219700362[/TD]
[TD]ANTIFREEZE[/TD]
[TD]1[/TD]
[TD]$0.00[/TD]
[TD]$0.00[/TD]
[TD]$0.00[/TD]
[/TR]
[TR]
[TD]219700362[/TD]
[TD]ANTIFREEZE[/TD]
[TD]3[/TD]
[TD]$0.00[/TD]
[TD]$0.00[/TD]
[TD]$0.00[/TD]
[/TR]
[TR]
[TD]509000045[/TD]
[TD]CLAMP-GEAR[/TD]
[TD]3[/TD]
[TD]$0.00[/TD]
[TD]$0.00[/TD]
[TD]$0.00[/TD]
[/TR]
[TR]
[TD]709200337[/TD]
[TD]RADIATEUR *RADIATOR[/TD]
[TD]1[/TD]
[TD]$0.00[/TD]
[TD]$0.00[/TD]
[TD]$0.00[/TD]
[/TR]
[TR]
[TD]709200384[/TD]
[TD]LOGEMENT THERM *THERM.HOUSING[/TD]
[TD]1[/TD]
[TD]$0.00[/TD]
[TD]$0.00[/TD]
[TD]$0.00[/TD]
[/TR]
[/TABLE]
[/TD]
[/TR]
[TR]
[TD][/TD]
[/TR]
[TR]
[TD][/TD]
[/TR]
[TR]
[TD][/TD]
[/TR]
[/TABLE]
[/TD]
[/TR]
[TR]
[TR]
[TD]
| Notes: |
7/26/13 Notify customer when parts come in we will need t o pick up unit and deliver back plan on keeping vehicle overnight.fp
7/27/13==2-3 days out on Radiator...Al
==Thermostat Estimated in 8/1/13..no tracking info at this time. 12:28, 7/31/13
[/TD]
[TR]
[TR]
[TD]
Labor: [/TD]
[TD] $0.00[/TD]
[/TR]
[/TABLE]
[/TD]
[/TR]
[TR]
[TR]
[TD]
Parts: [/TD]
[TD] $0.00[/TD]
[/TR]
[/TABLE]
[/TD]
[/TR]
[TR]
[TR]
[TD]
Fees: [/TD]
[TD] $0.00[/TD]
[/TR]
[/TABLE]
[/TD]
[/TR]
[TR]
[TR]
[TD]
Sublet: [/TD]
[TD] $0.00[/TD]
[/TR]
[/TABLE]
[/TD]
[/TR]
[TR]
[TR]
[TD]
Sub Total: [/TD]
[TD] $0.00[/TD]
[/TR]
[/TABLE]
[/TD]
[/TR]
[TR]
[TR]
[TD]
Tax : [/TD]
[TD] $0.00[/TD]
[/TR]
[/TABLE]
[/TD]
[/TR]
[TR]
[TD][/TD]
[/TR]
[TR]
[TR]
[TD]
Total: [/TD]
[TD] $0.00[/TD]
[/TR]
[/TABLE]
[/TD]
[/TR]
[TR]
[TR]
[TD][/TD]
[/TR]
[/TABLE]
[/TD]
[/TR]
[TR]
[TR]
[TD]
Balance: [/TD]
[TD] Warranty[/TD]
[/TR]
[/TABLE]
[/TD]
[/TR]
[/TABLE]
[/TD]
[/TR]
[/TABLE]
[/TD]
[/TR]
[TR]
[TD][/TD]
[/TR]
[TR]
[TD][/TD]
[/TR]
[TR]
BAR # ARD00261580
[/TD]
[/TR]
[TR]
[TD][/TD]
[/TR]
[/TABLE]
[/TD]
[/TR]
[/TABLE]
