SpyderAnn01
Plug kit and Aerostitch compressor. Joe seems to be a nail magnet on his various motorcycles so we have used it several times. I use the compressor whenever I need to add air and don't want to pull out our big compressor.
....... 6 CO-2 cartridges took it to 16 PSI. That put it just above "still flat" and no way was this loaded touring bike going to be ridden. Not saying they won't work, just don't put much trust in what four or five will do.......
I carry a small vulcanizing kit and a small bicycle air pump. I've never had a need for it in 30+ years of riding but I feel warm and fuzzy knowing its there.
So......how exactly do you FIND the puncture point in the rear tyre while you are out on the road by yourself.on your F3-T or RT. ? :shocked:
Pete
Just curious since we don't have any spare tires does anyone carry a can of fix a flat or something similar in case they get a flat tire and you just happen to be 30 or whatever miles from civilization. I was thinking about picking one up just in case. Jim
So......how exactly do you FIND the puncture point in the rear tyre while you are out on the road by yourself.on your F3-T or RT. ? :shocked: Pete
Will that little air compressor pump up a tire without blowing a fuse if you use a plug in on your Spyder? Also, are you sure that you can connect it to the valve stem on the rear tire? You might want to try it first before you have to find out the hard way that it won't when you need it most.
itSo......how exactly do you FIND the puncture point in the rear tyre while you are out on the road by yourself.on your F3-T or RT. ? :shocked:
Pete
it
Put the Spyder in gear, roll it forward or backward a bit at a time and check for something in the tire. If you find nothing it's time to repeat the process with some water and check for bubbles. If it's dead flat hook up your compressor and try again. That attempt is going to be a :cus: because of the valve stem position but if the compressor has enough oomph it might give you a couple of shots at the rolling before you have to reinflate -- not a project I'd enjoy trying.
