Front brake noise (clicking sound)
spydertrike
On my 2012 RT-S I find the front brakes making a loud noise when I apply the brakes. The brakes make a clicking noise. I understand it's the brake pads making this sound. The dealer advised me this is normal.
Does everyone find this happening with their Spyder ?
Is there anything I can do to soften this noise ?
My spyder does the same thing. What I find odd is that the right side always clicks first, followed shortly thereafter by the left.
Just sayin'.............
My 2012 RS clicks only once and it's only the first time you push on the brakes going forward after using reverse.
clicking brakes
My 2012 RS do the same thing .
My 2012 RTS left front brake will squeak when I first start driving but stops after the first or second time I use the brakes. I have 900 miles on it
Same here. On first brake, coming out of the garage, the front brakes will click.
Also, when I'm backing up, I can hear a slight hum from the rear brake. This has been documented by many others in the past as well, and it's not a big deal as I prefer to go forward, but just be aware that you may pick up on that too on your travels.
