spacetiger
But here goes. Mark, spacetigher is right. Move the one spacer to match the location in the coils like the other spacer. Use a jack to raise one or both sides of the spyder to remove the spring pressure. Use a piece of plastic or small wooden tool to pry the spacer away from the spring to make the spacer easy to move. Dawn dish soap makes the job much easier. I've remove and installed mine more than once to test the ride and handling. They are not difficult to remove and replace. If you don't think the spacers help to improve handling, then remove them and see how you like the ride. I have many thousands of miles on my spyder with those spacers installed and I've never had a problem with them at all.
I was hoping someone would do this...
Best free option to try before the harder stuff. There, no beating.
Jerry
