BLUEKNIGHT911
Sadly Passed Oct 2024 - RIP
I'm an equal opportunity octane user. When I'm on long trips with long freeway stints, I'll use 87/10% ethanol to save $$ at upper 20's mpg. Blasting around locally, I'll alternate between 87/89/93 with 10% ethanol and 91 at 100% gas. I do get a warm/fuzzier feeling with premium. Transitioning to fall weather, with rides less frequent, I use 91 oct/100% gas. I start adding fuel stabilizer around this time of year (I'm in WI). I cannot feel any difference in performance, but do get the slight mpg improvement with 100% gas. Now, is it worth the .80/ga difference in cost to feel warm/fuzzy?
From what I know of the Spyder computer fuel mapping …. switching Octane's is not a good idea ….. the computer can actually learn what octane it's getting, and will makes changes to it's mapping …. It's takes a bit of time to do this …. and if you change what you are using even sometimes, the computer won't be able to give you maximum performance. If someone knows better please chime in ….. Mike
