funk operation
Fireguy
My 2013 RT has an electric switch to open the funk When i put it away i removed the battery and closed the funk? It there some other way to open the funk?
FRUNK
Have you tried the normal way by pushing in the KEY and turning it ???.... I don't think they dis-connect the manual cable, if they did ........it was dumb......jmho......Mike :thumbup:
insert your key in the ignition and then press it down and turn it to your left, it will unlock the frunk, turn it to the right and it unlocks your seat.
Cruzr Joe
It's a bummer when that happens. They have you covered with doing it manually with the key. Good to have a back up system. :yes:
