Gas Mileage on a 14RT
Deanna777
Well-known member
I got 709 miles on my 14RTS-SE6 and I am getting ...................................................................Wait for it............................................................................................................39.5mpg. I am using mid grade gas. Deanna777
I'm sure that it'll improve as the engine loosens up...
By the way; did the mileage on Mike's improve? He mentioned getting about 32 mpg when I last saw him... :dontknow:
That's sure better then my 24-27 I'm getting, but that's much better
then my ram
How many miles do you have on your ST-L? I was in the same range 24-27 and then with about 4000 mile on the odometer it was like flipping a switch. It has jumped to a consistant 30-33 with a high of 36 and that is for the last 3200 miles mostly riding 2 up.
Bob: I will post here the mileage that I get. Send mike a pm and ask.
Deanna777
Gas AVG
:gaah:....tHAT 32 MPG REFERENCE was actually the highest I obtained coming back from ILL......Now I usually get between 38 and 40 MPG per tank fill-up at 4400 Mi. after first oil change to Rotella T-6 full SYN.........Of course I could get way better mileage ....ie at least 40 if I used Premium gas ......But I'm sticking with 87 Octane .....the RT runs smooth, starts good, and I pass anytime I want.......If I want to go Quicker than this ...I'll investigate a TURBO :roflblack::roflblack::roflblack::roflblack::roflblack:................Mikeguyver :thumbup:
I got 709 miles on my 14RTS-SE6 and I am getting ...................................................................Wait for it............................................................................................................39.5mpg. I am us. ing mid grade gas. Deanna777
I now have 3,000 miles on my 2014 Spyder RT Limited and am averaging 40 Mpg. I use 93 grade gas.
2nd tankfull
We got our 14RT 2 weeks ago and on the 2nd fill up we got 6.75l/100km or 34.8 mpg US. I'm very happy w/ that and it should only improve as the bike gets broken in. So much better than the 2010 RT-S.
Bruce
Cool! :clap: :thumbup:
2014 RT MILEAGE
:gaah:.....Bob what effects ( lowers ) my gas mileage is I do a LOT of PASSING.....which is worse than just driving fast on the Highway .......Except for that I'm sure I would consistently get 40 or 41 MPG's ..................and that would be on .....87 OCTANE ..." Texas " is actually getting better than this .....also on 87 Octane .......It would be one thing if I recommended someone try using 87 octane without having any firsthand knowledge of the consequences of doing so......However my mechanic and I pushed the 1330 engine until the......." KNOCK SENSORS " activated and the stress level needed for this to occur was much, much higher than 98 % of NORMAL driving .......Both He and I would recommend using 91 octane under the following circumstances .......Very steep mountainous driving WITH a passenger ......or an adult passenger and TOWING a fully loaded BRP trailer .................When I pass, I do so very, very quickly and so far I have not noticed the " knock sensors " kick in .Mikeguyver :thumbup::thumbup::thumbup:
Mine seems to be holding at 40 mpg now at 6000 miles. It went up steadily from 36 mpg at the beginning. Oh yes, 90 octane--highest available.
A DIFFERENT ROUTE
Mike,
Why are you digging? Nobody mentioned octane... :dontknow:
:gaah:....and some people mention lots of things that have no meaning ..............So :roflblack::roflblack::roflblack::roflblack::roflblack::roflblack::roflblack::roflblack::roflblack::roflblack::roflblack::roflblack::roflblack::roflblack::roflblack: Mikeguyver :thumbup:
