dragonridernj
I have read some horror stories about bikes being stranded and one guru on you tube suggest that the wiring harness on all newer bikes do not take kindly to adding electrical options so Im being a bit careful. That being said , Im fairly happy with using my Iphone or I pod in the trunk but would like to have a screen to look at when Im seeking directions. I don't have speakers in helmets and don't want to get crazy with blue tooth dongle, etc
Im hoping to use my old Garmin Nuvi as a stand alone GPS. Its simple enough to fashion a bracket for the handle bars using a $5 Nuvi mount from Ebay, but with regad to the wiring, I hate to mess with the OEM harness and I think the only OEM 12 volt powerlet is in the rear trunk?
What I was thinking was to feed the stock wire and plug from the Nuvi up through the center of the handlebar into my fabricated bracket into the back of the Nuvi but on the lower end Im wondering if I can modify the end of the cable to connect to the stock GPS connector under the side panel and exactly which prongs I would pick up for power only. I guess I could locate the positive pin with a simple meter . Where would I get the OEM connector to fit the plug under the side panel?
Any help is appreciated and my main concern is that I don't casue an issue with the OEM panel which could cause error messages or limp mode
I do sort of miss my old Honda Valkyrie LOL
