RICZ
Hello Ricz, You purchased longer screws to complete the installation? My concern was that the stock screws might be too short if the windshield is any thicker than the stock shield. It would seem that if this is the case, then the vendor would supply them or at least provide a source for them. Also, I thought that based upon the diagram on the vendor's website that the predrilled holes would line up with the new shield? Am I mistaken? Thanks again for your help. My shield has been shipped.
Since I had to add 1/4" spacers under the windshield, I assumed I needed longer screws. It turned out that I didn't, but I bought a set (thanks Ace Hardware) after ordering the w/s, so I used them.
Re the holes; They were a little too short - maybe by 1/4" or so - so I connected one side, leaving the screws a bit loose and I pressed down on the plastic to spread it and inserted the other screws. Sometime after that, I needed to remove the w/s and it had taken a set to the correct spacing!
It didn't bother me that I bought the screws, when the w/s cost only $160 shipped. Now if it cost twice that, as many others do, I would expect they be supplied. I am pleased that I got to use the stock chrome brackets and not have to use additional black ones.
