Had a dead battery that threw a check engine light & Code U0155!! How do I clear the light? Do I need BUDS?
Mikey
Well-known member
Ok, like I said above, friend had a dead battery that threw a check engine light, then changed out the battery with a brand new fully charged battery, and was hoping the light would go out, but it didn't! The bike sat all night with no battery because I had the new battery on the bench charging, I installed it, and started the bike up and the light didn't go out. So I am at his house without my riding gear, so I rode it down to my house to get my gear, thinking maybe if I took it out and rode it a few miles it would go out! When I turned into my driveway it threw a VSC and a limp home! I shut it off and restarted it that went out but the check engine was still on! I am getting my gear on and taking it for a ride, then check for codes! My question to the group is other than unhooking the battery am I going to have to find BUDS to reset the light? Thank you in advance!!!!
Ok, took it out for a 10-mile loop, it seemed to run fine, got back to the house, looked for codes and got a U0155, but it's still got the check engine light on! I got the keys out of it and I'm going to let it rest for an hour and see if that will help?! Anyone got anything else to try?
You should probably do a search on that code (do enter that code in the Search field, then also check the 'Search titles only' box tho!) and have a bit of a read of some of the other threads on this, but the thread below might be of help:
Some of the other threads won't make you feel too optimistic, so Good Luck! (y)
Try disconnecting the battery. Then hold the positive and negative leads of the bike together for a few minutes. Wait a while and then connect the battery again, +ve terminal first.
You could also look to see where the -ve lead goes from the battery to the chassis or engine grounding point. Take that off, clean it up and put it back, making sure it is good and tight and making good contact. Tight battery terminals and the bike's ground are important.
After that, if that doesn't help, scan the threads for U0155 and see what others did to solve the problem.
You don't say what year your friend's Spyder is so some of the answers may not apply of course to his engine type or model year. The other thing to ensure is that the battery is the correct type, a 350 CCA not a 220 CCA specification. Just because the new battery fits doesn't mean it can sustain enough amps whilst starting, causing various modules not to startup correctly.
You might want a multimeter and ensure there is enough voltage with ignition off, on, and on with engine running. You don't want to be down under 12 volts at any stage, preferably higher. You should be way up in the 13's with the engine running.
These things are electronically quite sophisticated with their CANBus systems, so they require a decent battery to support a working voltage under high current draw.
I think a Yuasa USA brand is the OEM fitment on mine and that seems to be a decent battery. New batteries are not always good, especially import brands without recognized brand names.
Hey Mikey. I suspect your VSS and Limp Mode as you turned into your house may have been you riding the brake a bit. Let’s put that aside for now. U0155 is loss of CANBUS communications with the cluster. You know the drill. You’re going to have to fix the problem itself before the code and light will clear. BUDS or disconnecting the battery does not help that. The fault is re-activating every time you turn on the key.
Find out a little history about how the battery may have gone dead in the first place. Any Mods? Wiring changes or damage! Plus, did the owner try to jump start it? TEST all of the fuses. I’m confident that you know how to activate and charge a battery. Probably not that. Remember that on the 2024 machines, that code also occurred because of the initial rollout of Apple Car Play before the software updates activated it. You don’t say year and model, nor how long it’s just been sitting around unused. Was this a garage queen for 2 years?
The bike is starting and running fine now, it's just got the light in your face! Yes, it has some stuff that has been hacked into the system that I may have to unplug!! I called a shop down State got an appointment to hook it up! My friend was the type of person who always hooked up to a tender when he put it away, and when I did the Spring service on it for his wife so she could put it up for sale, I took it back to the garage and parked it and didn't hook it up! The battery was junk, old, and due for a new one! I am really hoping that clearing the code will solve the issue so it can go down the road! 🙏 🙏 🙏 This is one of those times I wish I had BUDS!! :unsure:
Now, there is a cable available on Amazon that links to the Can Am data port that gives you an OBD-II port. You can plug a OBD-II scanner into that.
Now, you can read some codes, reset some codes, and observe some real time functions. Some OBD-II readers are better than others. It won’t give you everything, but if you already have a reader, the cable is cheap. I think a direct connection reader is better than a Bluetooth type, as that eliminates one potential source of connection issues.
If you have a reader, or can borrow one, and can get the cable off Amazon (they are pretty cheap), you may save yourself some money and a road trip.
I’ve no idea if it will reset your particular warning light, but you might give it a go.
It's like 40 miles from the house, and I want to get it resolved as soon as possible so it can go on the market and find a new owner! ;)
I have been reading this thread because I have a similar issue with a check engine light. I have ordered the cable from Amazon, but I'm wondering if you could recommend a scanner name or model, one that has worked for you? Did not mean to butt in, just hoping, thanks.
Innova brand (5410). Some of them support Bluetooth support to an app on your phone.
They vary greatly in price. If you buy it off Amazon in the Innova Store, you can usually return it if it doesn't work for you. Check the policy on the one you order.
I bought mine because it supported JLR specific codes for my Range Rover. You might want to get a cheaper one as you will be just using generic codes. I now have a 2026 Sea to Sky so I have not tried it on my current Spyder.
I took the bike to the shop and BUDS found high resistance in the wiring harness and a bad SAS sensor! If it had been just the sensor that's not too bad, an hours labor plus parts, but the wiring harness took that job right into a parts machine!!:confused: Oh and the SAS part has been discontinued, they found like eight sitting on shelves throughout the world for that bike. That just doesn't make any sense to me at all. I would think that, the particular part would be one of those parts BRP would still use forever, knowing they hate to redesign the wheel and carry things from one model to the other!
Your signature line says a 2025 S2S. If this the case, is everything under warranty?
Being a current model, your dealer can order the part from Can Am.
They should be able to get the part to your dealer from the central BRP warehouse.
It's not my bike, it's my friend's bike, a 2012 RTL! He passed away this past fall and I have been trying to help his wife. She's trying to get as much as she can out the bike, unfortunately, the price just got a lot lower!
Ah, I see now. The reality, due to the paltry availability of spares for that age of bike, it might be worth close to its value as a runner, as a parts machine.
As you have found, certain parts are difficult to come by, and therefore someone might be willing to buy it as a whole machine to part out and make some money on.
If it’s a clean example with reasonable mileage then the engine unit itself will have real value if it runs OK. Bodywork, throttle bodies, seat, instrument cluster, starter motor, wheels, suspension components, etc, all have real value and are difficult to find.
Finding a motorcycle breaker yard near to you might be the hardest part due to transportation costs if you can’t ride it there.
So, depending upon the effort you are willing to put in might mean the value is higher than you might realize.
Or it runs fine, if it wasn't for the orange billboard in your face you would not know there was anything wrong with it, but of course you would want to be careful not knowing how the bike will react in a tight spot, knowing that everything you do with the bike goes to the ECM when you're trying to avoid or react to a road hazard, steering, braking, tire traction all gets calibrated and self-adjusts for the moment!
U0155 means it lost communication with the cluster. Normally you might expect that after a battery failure perhaps as a stored code.
As your bike has sat for a while, and the dealer is reporting a high resistance in the harness, I'd start by disconnecting all the cable harness from the ECM to the cluster. I'd clean all the connections, male and female with contact cleaner and check for corrosion on the connections, especially the male pins will give you a good idea of where the corrosion lies. Disconnect the -ve side of the battery before doing this.
If the bike runs fine after this and the only thing left is the error code, get the dealer to reset the errors for you.
Do you have any other indications of problems? The code is possibly historical and needs clearing. Does the bike run fine?
The bikes been cleared and it came back after the restart, it runs fine, if were mine I would try that and replace the SAS! But there comes a time when you have to say to yourself, when do you fold your cards and say is it really worth the money. The book value isn't worth the shop bill! I care about my friend's pocketbook and the option that when we get all that fixed that another shoe may hit the ground then what do you do, throw more parts to it! The bike books for around $5000, the bill was going to be $3000, that's a no brainer in my book! It's time to turn the page in this book!
