Help With ESI Fender Tip Lights
Paula(Butch2025)
Memorial Member
We are trying to install the esi fender tip lights in order to put the mud flap lights on. As far as we can tell we've done everything right according to their instructions and when we turn on the light - blinkers - nothing lights up on the fender tips.
:gaah:
Anyone else have trouble and figured out how to make it all work?
Use you tester to assure you have power going to your tips...if so you they may be defective. Both being defective is unlikely.
Are they LED lights?
:gaah:
When I installed my LED tip lights I found that I needed both lights installed to work. I guess the bike needed the circuit to be complete.
We are at a stale mate, so I contacted ESI and got a very quick response. After a few emails they want us to call them tomorrow. So we'll keep you posted on what we find out.
hope you guys get better service then what I got :popcorn:, I had a painfull experience with them :barf:good luck in resolving the issue!
. The tip lights are the LED Type (correct)? You stated that in the original configuration they work but the kit doesn't. It appears you have a wire reversal in the kit or the inline module is wired wrong or defective. They fender lights are independent from one another. Are you taping into the correct wire at the mirror? Try the other wire.
We are working on my 2012 RS the kit plugs in down on the A arm then posi-taps into the blinker wire behind the instrument cluster.
One email from ESI asked what type of spyder and what color the wire is that you posi-tap. We're thinking a bad batch went out because the next email said to call them on Monday.
