hindle exhaust install?
fjcady
[h=5]i just got a hindle exhaust ir my 2008 spyder and based in measurements there is no room for a exhaust gasket... male 1.625 female 1.625 the instructions say i need a gasket also the part #on the instructions and the one stamped on the back of the pipe are different OMG 5 hrs wasted:banghead::banghead::banghead::banghead::banghead::banghead:[/h]
Really..!!
When I installed mine I just pulled off the OEM slid on the Hindle clamped down hooked up the one spring and done...the gaskets are at the heads and Y joint.. :dontknow:
Check out this thread....it also has a link to you tube http://www.spyderlovers.com/forums/...le-pipe-installation&highlight=hindle+install
I don't have a Hindle, (mine's a Two Brothers Racing unit).................my TBR slip on did not use a gasket like the stock S pipe did. The stock gasket came out stuck inside the stock S pipe; sounds like yours stuck to the outside of the collector pipe. Just pull it off. My TBR slip on came with some high temp RTV silicone sealer, to run a bead around the inside of the S pipe mouth; that didn't seal the joint completely for me, so I ran my Spyder up on some low profile car ramps to access the underside of my Spyder more easily. I used my finger tip to run force the high temp RTV into the S pipe/collector pipe seam; then used a shop rag to wipe off any excess RTV. Sealed mine up fine. Good luck! BTW: Ultra high temp RTV would probably be more appropriate for this type of application.........................just sayin'.
Not to long ago I posted up the summit racing part number for the band clamp we used. Works great and seals perfect with no glues needed.
