ulflyer
Well-known member
I have Non-OEM trailer hitch mounting plates which are held on
by the axle nuts. I want to remove the plates. However, the axle "nut" on the left side is welded/part of the axle. The right side has a removable nut, after which the axle is pulled out.
Doing this will cause the wheel to drop and I have no idea what
problem this might cause or how difficult it would be to re-install the axle thru the wheel.
Can anyone tell me what I might be up against if I tried doing this?
I had the hitch plates done at the shop when a new tire was being put on last year, and I've never removed a rear wheel.
Sorta doubt its something I want to tackle either, but a local guy wants to buy the hitch and I don't use it anymore. If I have to pay an hour's shop labor, it doesn't make selling it hardly worthwhile.
