Early this year is over! LOL. It's November.... Just giving you a hard time.
The top picture is what you want to avoid. The bottom picture is a correct install with equal distance (whatever that may be) between the link and the bracket.
What exactly would cause this, Ron? Is there anything that you would suggest using as a spacer to center the sway bar?
It's real easy to center the bar as my video shows under the Spyder and the plastic links and the spacing to the frame (link mounting brackets on the frame). You do not need to make this rocket science! I "felt" the gaps and even eye balling it is fine as my video shows. The point of doing this is so the links to not hit the brackets and break or damage them. If your off on one side my a little (small enough you cannot eye ball) I don't think that is a big deal. Again it's super easy to just eye ball them to be the same. It's really obvious once you get under the bike and look.
Bob
While I like your picture, Ron (I really do!), the next post demonstrates that your drawing isn't sufficient without a picture of the actual thing and those gaps depicted on it:
After watching the video, I think I understand what you meant, but it is obvious that your drawing doesn'r explain it to those of us who did not watch the video. So, the photo would definitely help.
I am not sure how to answer your question except to guess that you're not grasping the concept here. It is extremely simple and you may be trying too hard. There isn't anything you can do or need to do other than get the spacing between the outside of the links to the inside of the mounting bracket equal.
Ron, feel free to snap a frame from my video for a picture of the area. If you do not know how to do that I would be glad to do it from my original high def footage (not the youtube converted footage).
Ah hell.... give me a little time and I will do it and post the pictures.
Maybe tomorrow AM.
Then feel free to use them to add to your instructions or whatever.... I am glad to help people.
The most important thing is I think just about ANYONE can do this themselves. Really it is not major surgery or rocket science!
Stay tuned.
Bob
I did try that but none of the shots looked good enough to post. If you can get a good, clear, identifiable shot that would be great.
This is a little video I did on how to install the Baja Ron Sway Bar in a 2011 Spyder RT. 2010-12 is the same.
Sorry for the shaky video as the iPhone does not have optical jitter correction! It's the only camera I could use and get under the bike to film. But this video should explain all the steps to install the bar. Enjoy! I have to say, this was far easier than what I have read! Don't be afraid to do it. Just some simple tools is all that is needed.
Video is in 2 parts:
Enjoy,
Bob
have access to a loading dock and a trailer? Baja Ron sway bar & heim links install on a 2013 RT-Limited install - ideal conditions...!!
and I know there are folks out there who are or were as unnerved as me by the "spyder dance" when they first took their spyder for a ride over 55 mph, got in a semi backwash and/or thru some twisties... and heaven forbid if you experienced this for the first time with a passenger!!!
Let me be crystal clear here, the Baja Ron sway bar Should Be STANDARD issue on every Spyder leaving the factory. Make no mistake, Ron's sway bar transforms this machine in an immediate and dramatic way... I no longer have visions of my untimely demise if I have to make a steering correction mid-corner anymore. The handling dynamics of this machine went from a 3-stage(lean, suspension loads, then oversteers) characteristic, to now, it just goes the way you point it - immediately and precisely-one motion..... This will be the best $$$ you will ever spend on an accessory for your Spyder - make no mistake - just do it.
Bobs video's are great. I learned how to build a RC helicopter from his video's:clap:
Enjoy,
Bob
This thread is indeed very valuable. The hemi links apparently weren't replaced in this video. Makes sense to me to replace plastic with metal. Is this a 50/50 deal as to the value of replacing the links at the same time or more like 25/75, its smart but you can live without, or 75/25 "you are an idiot if you don't?
Thanks
Hi bob,
Re: I have since added the metal links.
Was it an 'easy' job?
Just wanting a non-biased thought,
Jerry Baumchen
