mecsw500
I added the following 1-1/4" bar risers to my '26 S2S, found on Amazon.com for $47.49 with the coupon. They were nicely made, both machined and their coating. It said up to 2025 model, but fitted my 2026 as expected.
Made more difference than I thought it would. I rotated the bars more centrally to the locating pin when clamping the bars in. This made the turn signal switch a little easier to get to by feel with my gloves on.
The only thing is you will need a 6mm hex driver to get the old bolts out and an 8mm hex driver to get the supplied bolts in. I used a bit of blue thread lock on the new bolts and did them up in a star pattern bit by bit. I reused the original washers. I was careful and jammed a cloth down around the steering head so as not to lose a washer down the gap as the washers are very light and may come out with the old bolt and drop off into the void. One of mine did and the cloth caught it.
I can recommend them, especially for the price. I was dubious, but took a punt, and it turns out they were very well made.
Black 1 1/4" Handlebar Riser kit for Can Am Spyder F3 /F3T /F3LTD All Years, Spyder RT RT-Limited 2020-2025 Handle Bar Riser Models
