I am adding highyway pegs what panel to remove for heat and how
kbwitt
Please someone tell me what panel and how to remove it. I have blocked off the radiator vent so it will not blown on foot, but looking down I see a hole wondering if it will be sufficient for hot air release.
2014 spyder Rt adding Rivco highway pegs and have blocked off right side vent..
Rivco on way here maybe they will give instruction on this?
Thanks Kenn
check on the spyderpops website. Tey are one of the sponsors here and have the plate you need and the instructions all on their website.See the home page here and look for Spyderpops.
Took the underside splash panel off the right side..
Thanks Kenn
It seemed to let out a lot of the heat that was coming back under the "tupperware" panels on our 2011 RT. On our 2015, the much improved cooling system and reverse flow fans at low speed have pretty well tamed the heat, but you may find the need to open up the bottom by removing the underside splash panel. It makes for easier oil changes, but the trade-off may be more dirt accumulation under that side?
