Metalman
When doing my first oil change, I lifted the Spyder with an aluminum craftsman motorcycle/ATV lift. The Spyder is quite a bit heavier than the motorcycles I've lifted with it, but it picked it up fine. I used concrete blocks under the three wheels, so the jack could be pulled out to access the drain plugs and to stabilize the trike. Today, I built a set of blocks out of two by fours and decking screws to use instead of concrete blocks. They are obviously much lighter and lift the trike a bit more than the concrete blocks. I used 12 inch and 10 inch long two by fours.
