I hate Squealing Brakes - any suggestions to stop them squealing?
SQUEELING BRAKES
I put new brakes all the way around on my Spyder two weeks ago everything went good. But today I was out for a ride and they started squealing on me at every stop. Does anyone have any idea what could be going on. I bought the brakes from Bagaron.
I've also used Pads from Ron ..... never had any " Squeeling " :dontknow: .... or any other odd things ..... Question after you put them on - were you able to spin the tire ???? ....if not I think they are rubbing on the rotor ..... Mike :thumbup:
Hi Mike yes I was able to spin the tire. I took the tires off to c if something was out of the ordinary but everything seems ok. When I had one of the front tires off I noticed it had little round bumps on it on the top closets to the bike and yes they r the junk Kenda tires have u heard of this before.
Did you follow Ron's instructions for bedding-in the new pads as below?
"On a safe, straight, open road with good traction. Speed up to about 60 mph and slow as quickly as possible (hard braking) to about 20 mph.
Then, immediately speed up to about 60 mph again and Repeat this hard braking scenario 4-5 times in rapid succession.
DO NOT COME TO A COMPLETE STOP anytime during this process.
After the least sequence, ride, (without stopping if possible) for about 5 minutes to allow the braking components to cool evenly.
The idea here is to get the brake pads very hot. This cures the resins which bind the braking material and also mates the brake pad surface to the rotor surface giving you 100% contact area. You will smell hot brakes, but continue with at least 4 complete sequences. If you do not smell hot brakes, you are not applying enough force and you will not get the desired results. These are intended to be, pretty much, emergency stopping scenarios."
Baja Ron's EBC pads do come with instructions about putting on the CDC Disk Brake Quiet. Were you using the EBC pads and did you use the Disk Brake Quiet on the backs?
Yes I did all of that and they were fine for a couple of weeks
Yes I used the old ones from the back of the pads and installed them on the new EBC pads
I did the same as you and have noticed squealing while braking after a few weeks of riding. No squeal at first after changing them. I'll have to pay closer attention but I think the squealing occurs at slow speed stops only, and maybe only during light braking.
SQUEELING BRAKES
:agree: ....and followed this procedure also .... no squealing either .........I couldn't get the orig. metal backing plates on mine, it was too tight a fit , but I did use the paste ...... Mike :thumbup:
I just did mine with Ron's pads and I also cut 2 grooves into the pads as suggested. Its been a week with no squealing and only time will tell. Mike
No Squealing
I just installed all sets, both front and back, brakes on my 2014 RTS. Installed as suggested by BahaRon and have had no squealing. Took the Spyder out and preformed the required speed stops and road for about 15 minutes after, and I have not had one squeak. I did no install the backing plates form the original pads, as Ron suggested the EBC pads are thicker. Hope this helps.:dontknow:
On my short ride this morning for coffee, grocery store, and hardware store my brakes didn't squeal at all. I wonder if it may be temperature and/or humidity related. This morning was cooler than lately, and so humidity would have been up a little. Maybe when ambient temp is up, or humidity is way down, they want to squeal. I'll have to keep paying attention and note what the conditions are when I hear them squeal.
Brake squeal is usually caused by vibration not the disc rubbing the pads. This is the reason for using the CRC Disk Brake Quiet paste.
Just curious, squeal is sonic vibration and something is causing the vibration. What would it be if not the pads rubbing on the discs? That's the only thing that changes between squeal and no squeal while slowing down. Or is this what you intended to say but some words got tangled up!
True, the pads rubbing the discs is what sets up the vibration. The pads are rubbing the discs most of the time although very lightly. When you apply the brakes there can be a very narrow window where the conditions are just so and you get vibration and brake squeal. This window seems to appear at slower speeds as we approach a stop, but the squeal is not coming from the pad/disc contact it is coming from where the rear of the pad contacts the caliper piston. Applying the Brake Quiet paste to the area where the back of the pad contacts the piston will form a sticky bond that will cushion against this vibration. When the brakes heat up a few times the bond gets stronger. The various sprays and cleaners that claim to stop brake squeal will work temporarily, but I am pretty cautious when it comes to spraying anything around brake discs that may compromise my braking. Back when we were campaigning a race bike I was the team member in charge of wheels and brakes. We would spend thousands of dollars for the latest, greatest brake setups. They gave us amazing one finger on the lever stopping power AND often they squealed. We used Brake Quiet paste on those and I use it on my brake jobs. It's easy and it works. Sorry I didn't get my idea across clearly. I am a rider, not a writer and I need to stop trying to be the latter.
Wife and I lived in England for a year back in '88/'89 and I worked in Birmingham. I still clearly remember the incessant squealing of city bus brakes. All day long every few minutes! I think it might have been a "British thing".
Brake sqeal
Problem solved a buddy from work who is also a heavy equipment mechanic told me to ride around a little bit pushing the brake a little as I am moving to heat the pads up. Also he advised me to stop hard with the spyder. I did that for a few miles and now there is no more sqealing. Works good. But thanks for all of the responses.
