The back of the pads should have been buttered with that compound that go's on to keep them quiet, don't remember what it's called, but when I got my last pads from bajaron, he sent me instructions to use it and I told myself I didnt need it, but guess what, off the pads came and I went to the auto parts store and got the stuff and put it on!!! It will work for you also!! Good luck, sorry for the bad news!! Good Luck!
The bubblegum stuff recommended will stop brake squeal for sure, but the next pad replacement will take extra time cleaning up.
This stuff works very well, and brake cleaner washes it away. Water does not.
This, and new pads, solved the squeal on my 19.
To OP... who did the pads? It is possible to get the pads in wrong, where leading edge is located at trail. Also, were they factory pads? I've not seen an aftermarket kit come with the retaining clips, and removing those from the old pads can deform them, making new pad install difficult. Just might want to verify everything is assembled the way it should be.
" I've not seen an aftermarket kit come with the retaining clips" EBC pads do come with the the clips and have done for about 2 years. If you got some without the clips call EBC and they will send you some.
Did you go through a new brake pad break in procedure, or resume normal riding? If no break in runs were done, do it.
So, I can't remember the last time I replaced brake pads that had the anti rattle shims in them. Would you use the caliper grease/disc quiet lube on both sides of the shims, on all metal/metal surfaces, or just between the shims and pucks?
EBS's motorcycle pad break in procedure will likely only happen in a perfect world. 300 miles of gentle/gradual braking, followed by multiple hard stops and cool downs. Best advice is to just ride/brake normally and hope no critters run in front of you or vehicles turn left in front of you.
About a month ago I removed all my pads for inspection. With about 7.8K miles on the odo, all pads were in great shape. I lightly sanded the pads to remove any glazing. I popped off the front rotors and gave them a good cleaning (did the rear as good as I could on the bike). I applied a thin layer of Brake Quiet to both sides of the OEM brake pad shims, cleaned the caliper and reassembled. About 300 miles later, my rear brake is slightly chirping again, but it goes away when fully warmed up. Oh well ....
I think where some people make the mistake is they don't let it set up before reassembly!!
