Is a replacement Lithium Battery the way to go? How have you installed yours?
I have gone to the Noco 20 battery 1 year+! Jury is still out on it in my book, we'll see if it holds up as well as the stock brand! I will say that I love the charger I got with the battery, it does the standard batteries as well as the Lithium!!! works well in my book. Battery, I will let you know in a few years!!
If you're just worried about moving in the box you could use some Styrofoam or dense rubber foam to fill up the open area.
I just modified the bracket a little so the battery clamp would fit into the NLP recess (only took a few minutes on my grinder). After that it was as solid as factory. Put 2k miles over the summer on trips with no issues.
I have just bought and am about to install a BS lithium battery - BSLi-10 - to my 2019 F3-S. Has anyone on here got one of these batteries?
If you've been using a battery tender, make sure it's designed for lithium batteries.
