It's Heeeeerrrrrrreeeeeeeee!!!!!!! Navigation!
hogmemberisold
Ok,
Last night BRP Go! update on my android phone and gave me an indication in the app that navigation should be available now on the Spyder....
This morning I pulled the bike outside closer to the 2G wifi and now the bike is updated to V5.## software and shows a heading of "Navigation" in the menu.
We are heading out of town this morning so I will mess with it after getting back...
Just a heads up to those with a 10.25" display... It's Heeeeerrrrrrrreeeeeee!!
Actually it is a connection between Android or Apple phones and the BRP GO! app on the phones that allows the embedded navigation of the app to show in the Spyder cluster, not the full Android Auto mais certainly a solution for Android phones owners. Only applies to the 2024 + new 10.25" dashboard, which has to be updated to V5.1.0 from the previous 4.1.0
Installed the update via wifi. Downloaded the BRP GO app and registered. Connected my Samsung phone via Bluetooth. Opened the applet to navigation. Opened the BRP GO app on my phone. Plugged in a USB A to USB C cable. The app connects for a split second and then disconnects. The phone switches from charging only to transfer data, back and forth for a minute or so until the app says it can't connect. I've tried several different cables to no avail.
Updated on 2026 s2s ....and now there's no Apple car play.:(
I have provided you with the solution in your other post here :
I have a Galaxy S22U and experienced the same thing after updating for the nav. I was able to fix it by going into USB settings (drag down from top left corner and select USB connection) while connected and changing it to "Controlled by Connected device" (vs default "Controlled by This device"). Once I changed that it auto switched to transferring files/Android Auto (from charging only) and all was well...
Thank you! I will give that a shot.
Are you referring the usb settings on your phone?
I can get to the point where it tells me I have a bad cable or to clean ports?
I'm not good with technology..sorry for my question.
