Jack point?
jack points
On the underside of the bottom frame member there are two holes. I made a circular 3/4" wood disk with a 3/8" short bolt protruding above the top about 1/2" and insert it into the cup of the jack. This stud will position the jack in either location and prevent the jack from slipping on the metal frame. To raise the front only, jack at the forward hole.
+1 I missed the previous thread you had with the atv/motorcycle jack from HF. Going to pick that up soon. Looks like it makes things easier than a low profile lift.
