Keeping up with that key - anyone fit a lanyard?
lilwill
How is everyone keeping up with there ignition key. Due to the design of it I can't see how to put a lanyard on it.
There are several options out there from covers that let you put them on a keychain to drilling holes in them. I have always used the OEM sheath and have no issues with it. A google search on "can am spyder key fob" returned a lot of results.
I keep the OEM sheath on a small keyring in my pocket. When off the bike, I slip it in the sheath and it's in my pocket. I've never worried about losing it.
Ignition Key
attachment.php
I recommend keyport replacement & keep the OEM as a spare. https://mykeyport.com has room for 6 different keys however you want to make work for you:2thumbs: More pics in album
A quick search/check of the Forum and you will find a lot of solutions. The drilling one is a bit tricky if you miss the spot. The sheath has worked well, and even though I thought it would wear out, it hasn't... :thumbup:
I bought a pair of them on Ebay for $42.90....so you have to watch for the best deal....They work GREAT!!!!:thumbup:
I use the original sheath that came with the Spyder with a neck ribbon. Works great. Normally I leave the key in the ignition. Not to worry. Who can figure out to start it anyway?
Jack
Thanks everyone, I'm going to try the drilling option, I didn't think u could do it because of the chip
I must be missing something.
I truly don't understand why some people don't use the sheath that comes with the key. When I first saw the key in the sheath, I was a little puzzled for a few minutes, but then I thought, "What a brilliant idea"! Why drill a hole in the key when the sheath already has a hole? I have the sheath on a key ring with some other keys in my pocket. When I'm ready to ride, I just pull the key out of the sheath and put it in the ignition - with nothing hanging off of it. When I get off, I just slip the key back into it's protective sheath. I don't want anything attached to my key. The sheath protects my key when it is not in the ignition and keeps it handy and secure. You can use it on a key ring, a lanyard, or any other attachment that makes sense to you. I can't figure out why anyone wouldn't want to use it.
This isn't a criticism, I just don't understand. :dontknow:
What does this key sheath look like? I bought my bike used and I haven't had an issue with losing keys, but now I'm curious.
Pat
You bought a used Spyder, that explains the question. Spyder keys come in a form fitting sheath that is a little bigger than the working end of the key and has a key ring on it. The key hangs upside down. If you don't have it, the thing I would do is drill a hole in the key as described in #8 of this thread by Lamont. By the way, he has some great videos on his Lamonster Garage site.
If you carefully note the positioning of the drilled hole; take an awl, and probe that area first. nojoke
You'll be able to push It right through the key, when you hit the "sweet spot"! :thumbup:
I drilled my keys, because I wanted to attach the key for the Lidlox right to them.
Pat
Pic of sheath.
You can get from your dealer if you need to. Can still be annoying IMHO, which is why I went keyport.
No digging, no jingle, & just right for my needs. https://mykeyport.com
Fyi, with Lid Lox key on the end.
