UtahPete
Well-known member
I have a Monster Stage 2 ECU Flash and now I'm installing the cat delete pipe. I'm a little confused about whether or not I should install the baffle and if so, should I also install the plug in the baffle?
I've read all the threads I can on the subject and found nothing definitive, particularly with the ECU Flash. Some say install the baffle but without the plug to provide needed back pressure. BUT, I have not gone to a straight-thru muffler - I'm staying with my OEM muffler; does that by itself provide enough back-pressure or do I still need the baffle in the cat delete pipe?
What about noise? Jane is not interested in having additional exhaust noise when we are two-up touring.
I'm looking for an opinion from someone with technical knowledge. Thanks.
