Last day on -14 RT...
prmurat
For my last day of "ownership" I decided to put on the ECO mode and be a good boy: cruise control set to the speed limit, let the machine downshift by itself etc.
Once the "Easier Companion Option" is on you have to stop looking at the road and concentrate on the gear indicator which turn in a up-green arrow when its time to shift up... On the flat you can be in 6th right before 50mph and kept it till just below 40... Engine seems to not suffer from this treatment: smooth acceleration from over 40mph and mpg way up ( or is it down?): 36mpg...
Which at the price they sell gas on Hw1 is more than welcomed:
I am sure when riding on the freeway for days at the time it will make a huge difference but for fun/every day riding, shifting up gears like a Parisian taxi wanting to save some diesel with his stinky Peugeot is not my cup of tea.
I think I am able to summerize my impressions:
Do not like:
-chrome accents/wheels on the Limited (so I'll get a RT-S).
-Throttle needs a little more freeplay, it is almost always on.
-rider floorboards need to be horizontal, not tilted to the front.
- not being able to get in 1st gear without using the brake.
- having to press on R first then on the back paddle to shift in reverse.
-too soft front seat after a few hours or too high windshield: position is perfect in the morning but "sinks" after more than 2 hours on the seat.
-the dashboard: forget the analog speedo and move all the "idiots" lights and others informations on that side.
Love:
- the engine: powerful, smooth, torquey
- gearbox is perfect, if a little bit noisy when changing the first 3 gears, up and down.
- new geometry of the frame/front wheels: a lot more stable, more confidence inspiring.
- brakes are superb: biting well and never fading, very progressive.
- nannies are not as intrusive as before: a little flashing light to warn you and then, if you keep the same tempo, some actions to slow you down.
-passenger overall is much more comfy than before: seat is better and the absence of roll helps a lot in the twisties!
- I do not know about error codes and the safe mode results (did not have any in 600 miles) but when I did hit the brake and the throttle (see above why) at the same time, it did not show any error code as on previous model, just a nanny brake and that's all. No need to stop the bike etc.
- the engine sound.
What I would like:
- moving the front meshes protecting the radiators completely to the front, maybe a one piece covering completely the "mouth". It will stop debris to stay in there and would be a nice "accent" in the front (black for me, thanks!).
- apart of braking what's the use to have Brembos in the front, if they are not gold with red lettering ?
- maybe a little emblem/lettering about the size of the engine? Number of cylinders?
- what about having 3 little pipes out of the muffler à la Triumph T150 (-69)?
- all the chrome (or brushed ) accents in black?
Now... I have to bring back this RT tomorrow morning... Should I disapear in the sunset and ride it till the Police finds me or just do the usual things: check my credit rating, take a third mortgage and sell some blood just to be sure I'll get my own soon??
Thanks for the write up. You have added some good information to our data banks. :thumbup:
You are like me I love the blacked out pieces! I drove a car a few weeks ago with that Eco mode thingy and it drove me crazy, kept seeing that lighted "eco" go on and off and I found it very distracting but if you get 36 mpg using it I might have to give it a try.
Oh, if it was me I'd just keep riding.................
May I suggest you do an immediate 180 and head up I5 straight away for Richmond.
I even buy you great dim sum; just me have a ride! :thumbup::roflblack:
Glad you got a chance to test ride the 2014 RT! :clap:
Quick questions just for clarification....
Do not like:
Regarding the tilted floorboards.... could they have been in the 'emergency released dropped-down' position' and you might not have been aware of it?
I have not seen this feature activated in person, but the BRP 2013 Demo Video introducing these new floorboards showed them in the flat horizontal position before they were released by extra toe pressure as may be required in emergency braking. As soon as the extra toe pressure was applied, they tilted down to the front until they were reset to horizontal by heel pressure applied to the rear of the board. I recently took an STS out for demo and it had the full floorboards in the tilted position and they were uncomfortable. I forgot to check and see if they were in the released position. I only remembered it when I got home.
Regarding the seat "sink".... Was it the heated Comfort Seat or the stock seat ???
Thanks for a great assessment. I'm about to place an order and your comments are appreciated.
gregp
You probably should return it to them... :shocked:
And then start checking your credit rating, and when the bloodbanks open!! :2thumbs: :D
There's also babysitting, lawnmowing, dogwalking, painting, and selling newpapers...
Huh... that's crazy, I had no idea they implemented such a thing!
It's a minor thing, of course... except when it isn't! Personally, I've gotten quite used to having "flat" floorboards (Rivcos on my RS), I don't like a down pitch much at all.
BTW, this one confused me:
"- having to press on R first then on the back paddle to shift in reverse."
Haven't we always had to do that? That's the procedure on the RS... :dontknow:
You got me thinking and this is the 1st thing I did on my 2011 when I took it back... on mine I can press both switch at the same time...maybe something changed in the 2 years models?
And I do prefer my footpegs compared to the titing floorboards!!!
"PR"
I've been thinking about your comments regarding the procedure for finding reverse gear...
You describe it as, "Pushing the 'R' Button first, and then hitting the downshift paddle"; is that correct?
It would seem that this would be the natural way to perform this anyway...
Just lay your thumb on "R", and roll your left hand counter-clockwise to catch the paddle... :thumbup:
Thank you for the tip... Too bad I've not done it this way on mine for 2 years: I've now to break a, working well, habit!
That can be rough... :shocked:
But if you were smart enough to wrangle a 2014 out of BRP's hands for a weekend; it should seem easy in comparison! :2thumbs:
