downeastryder
Howdy Spyder Heads.
Ive dug myself into a bit of a hole. Whilst doing a variety of electrical work (adding driving lights , LED rear lights that tap into the brakes) everything was going smoothly then a series of not good things happened.
It coincided with putting some air into the rear shock thingy (actual name?) but not sure how/if connected. I was pressing the brake to check the functionality of the rear LEDs (they are RGB, able to run dim and then up to full, triggered by brake pedal/lights) and running it without moving it. (the frunk is still off and up on front jack stands)
Limp mode came up, wouldn't start. EEEEEK
I started walking back the taps and even just all additional wiring. I am using a fuse block from Denali that was working well initially.
these fault codes are up>
P0113 (Air Intake Temp something)
P0556 (brake boost)
P0504 (brake)
P2228 (barometric something or other)
The research may have yielded results from other codes/machines, so any clarification is welcome.
Is there a way to clear them without a BUDS, service call?
Battery has been disconnected, making no difference.
HHHEEEEEEEEEELLLLLLLLLLLPPPPPPP....
Some back story, bought the machine in October, rode it some before the snow flew, and got in some little rides here and there as Maine had a light winter. Ive installed a sway bar and shock spring compressors from BajaRon, threw on some centrmatic wheel balancers while the front wheels and fenders were off while installing the front reflector replacement/upgrade. This spring I slapped on the rear bag running lights/blinker set and replaced the fog lights with LEDS while the frunk was off, and added a set of LEDs to the rear, tapping into the brake light. I was running it and using the brake to test the new light functionality and then limp mode popped up, then went away, but it won't start, and then retrieved the fault codes.
Super frustrated and annoyed with myself and the complexity of the wiring and all that "extra" spyder stuff under "the hood"
Any help appreciated, sarcasm unwelcome....
Thanks, looking forward to a realistic forum for tips and advice. Facebook has moments of sanity, but a lot of fluff....
Downeastryder/Downy
P0556 (brake boost)
P0504 (brake)
Downeastryder/Downy
