Low moan coming from Spyder
Showie
Wondering if anyone has had this problem. I noticed a low moan coming from spyder about a couple of days ago. Like most squeaks, rattles and moans I can't figure exactly where or why. At first thought it was coming from front area. But after putting my spyder in neutral and rolling it around driveway, I think the noise is coming from under seat and keeps time with rotation of tires. Seems to be 1/4 +/- rotation moan in for every rotation and a half. Not exactly sure. Can hear at very low speeds not at higher speeds. Engine noise to loud. Looked at brakes but can see nothing.:banghead: Thanks in advance for any help and suggestions.
Use a jack and lift your:spyder2: so tires will all off the ground. You can now check your underside, spin your tires and find this moan. Check out off round disc brakes and wobles, axle bearings failure bad race? Good luck. Let us know
what ever you find.
Teddy has a suggestion to help us better help you
As I'm sure your well aware, the SpyderLovers community are a very helpful group of characters, most willing to do what they can to offer advice or assistance with almost any Spyder related problem out there. The old adage of 'Too much is better than not enough' is often an issue we run into, when it comes to information :dontknow: to help solve a problem that someone might have.
Teddy suggests that its a good idea for everyone to set up their profile SIGNITURE LINE with information that others may need to help answer a question that someone may pose, like the YEAR, MODEL, MILES, & list ANY MODS that have been done to their Spyder, that way, everytime you post, all this info will be automatically listed at the bottom of your post and you won't have to worry about typing it over & over again, & ppl that are trying to help answer your questions won't need to keep asking for this info ;)
As always, your free to do as you choose or don't choose to do in here & thats one of the things that make this such a great site :firstplace: Teddy just thought he'd share, cause the more info we all have about an issue, the better we all can help the person needing assistance :thumbup:
Low moan
Make a careful inspection of your undercarriage, and extricate neighbors chihuahua from around rear sprocket. :p
Seriously, mine does pretty often as well. I think it's brake related.
R right Cyncy. Sorry for not putting enough info. 2013 RT S. Will try to figure how to do profile :pray:
Moaning..!!
sounds rotational. Check disks, drive belt, drive sprocket, for rubbing or dragging. Check that the park brake is not adjusted to tight etc. Good luck they are hard to find at times..!! :thumbup:
Sorry...I can't handle this thread. Moans coming from the Spyder...probably rotational....check undercarriage......just too much! :opps:
Wow! :shocked: I could get smacked with the "Ban Hammer" for all of the stuff that could be posted... :roflblack:
...But I'll just run with the neighbor's dog caught in the driveBelt story... :D
Most likely from the belt, although brakes have been known to moan, too. If it remains when you apply the brake, it is likely the belt. BRP has a service bulletin which applies a makeshift, temporary fix by greasing the belt in a specific manner.
Sounds like the rear brake. My 2011 does it too and the dealer says that is normal with the type of brakes that are installed. It pretty much only does it when it is cold and does not seem to wear the brakes at all (I'm still on the original with about 30-40% left at nearly 31K miles).
Your bike is possessed...
My 2012 RT A&C moans when I push it out of the garage backwards with the engine off. :dontknow: Nothing when I push it forward.
I hear it most often at the gas pump:D And while backing, particularly from back aft, done it since day one and with second pair of brakes. Seems normal to me.
