Manually downshifting SE6 ?
Marr
How many of you manually downshift all the time ? I had a manual shift 5 speed 2011 RT, and I got used to downshifting when I was coming to a stop, and now do it all the time on SE6. It isn’t hard on anything to do that is it, or wear anything out ? Seems to me like it kinda saves on brakes a little bit. Just wondering if I’m wearing something out trying to save something else. Thanks
If I'm coming to a full stop, I'll let the system auto-downshift. I'f I'm merely slowing down temporarily, I'll manually downshift.
I always manually downshift (SE5 or SE6) … this keeps the Spyder in the "power band" range in case I have to react to a negative situation. Won't need to downshift as part of the reaction, I have already done so.
All the best …. Ann
I let it downshift by itself around town most of the time but if we're doing twisties I'll downshift and back-off the throttle before the turn and let the 12:1 compression ratio slow me and have power to pull out of the turn.
All the best …. Ann
You saved me all the typing. This is my answer as well. Always be prepared.
All the best …. Ann
Do the same for the same reasons
Devaluation by age is the major expense with any vehicle.
If your worried about wearing out the transmission before the brakes or vice versa your barking up the wrong tree.
Ride the hell out of it and worry less.
If the transmission goes out to lunch it is a piece of crap and you can then come back and tell us all and we'll stop buying them.
On ours, it is mixed. Sometimes I let the machines computer do it, other times, I grab the gear.
FWIW, the item that will fail is the left grip shifter. Ours and others have had to have the shifter replaced.
The gearbox, clutch, and drivetrain can handle it without concern, far less stress than high power upshifts.
The nanny (computer) on the bike won't let you downshift if it doesn't deem it safe. Same as up-shifting, if the RPM's are too low, it won't shift.
Thanx for all the replies. It just kind a seems the normal thing to do, just wanted to make sure I wasn’t going to screw something up.
Newbie (Spyder) here. I've had my 'ol Triumph 35+ years and always downshift, so I'm very used to the idea. I've now had my '18 RT SE6 since July and cannot seem to get it to downshift without what I think is an extraordinary amount of force on the paddle shifter. In the last week or so as the weather has tuned cold, it is reluctant to go into reverse. To describe the force I apply, I feels as though I could break the shifter. Question is, does it take a lot more force than upshifting to downshift? I'm taking into consideration the RPM vs. road speed and what the nanny does to limit "mistakes". Other thought is, are the paddle shifters problematic and perhaps the problem is there?
The paddle shift switch is just an electric switch. RPM and road speed have no effect on it. If it is hard to move, you need to get the switch fixed.
RE: Downshifting the SE. In most cases, I let the :spyder2: do the downshift when it determines the rpm's are ready for the next lower gear. One exception, if I need power now, I will downshift it manually.
This is a known problem with some of 2018 models. Take it back to your dealer and have the left handlebar controls replaced under warranty.
Light touch is all it should take. If yours is different, take it back for the dealer to fix it. This is a known problem on some 2018s.
Appreciate all the fellow ryder comments. I always knew something was up, when the reverse problem showed up I was convinced. She's off to the dealer today in fact!
