Hey guys, I need some help here. Recently bought a 2012 Spyder RTL. took it for a couple of short rides and ran good. then all of a sudden started running bad. here are the symptoms.... stalling, front cylinder not firing. has spark and fuel. i replaced the plugs and wires, i also replaced the map sensor for a code it had. i cleaned all the connectors, checked the filters replace the vacuum lines and cleaned the throttle body. i did some testing today and found when the cylinder is misfiring that it is getting spark and fuel. I thought I had an intake valve sticking because you can hear a clacking noise when it misfires and there is air being forced out of the throttle body instead of sucking in, on that front cylinder. I added some Yamalube fuel treatment today hoping if it was a stuck valve that it would free it up. Got everything back together and went for a 20 mile drive. ran great the whole time. i got home and parked it thinking i had solved the problem but when i restarted it, it started misfiring again, so disappointing. I think I have done everything i can at this point and am on the verge of sending to the dealer. I have been a mechanic for 40 years but I don't have the proper diagnostic equipment to work on this. I would appreciate any thought you might have. Thank you
