IdahoMtnSpyder
Well-known member
I just finished on Friday, 8/8, over 1700 miles to and from SITR. My RT purred like a kitten the whole time. Much of the travel was in 90° + temps. I had no significant heat problems at all. The only heat mod I've made is blocking off the upper air hole so my foot doesn't burn up when it's on the highway peg. My right foot hardly ever felt hot while on the regular peg as well. I don't recall ever seeing the engine temp gauge go above 4 bars, even when the ambient temp gauge showed 111° east of Redding, CA. I always filled up to the very top, and a few times even spilled gas I topped it off so high. Had very little gas fume problems and don't recall ever hearing the gas boiling when I opened the cap. I had some gas fumes in the garage after I got back, and that was with a nearly empty tank. I noticed gas fumes when I left the bike idling while checking out local scenery along the road. That was full tank, half tank, and close to empty tank. I agree with others that gas fumes are not caused by overfilling.
The Rotax engine runs quietest with a little load it seems. 4th gear at 61 mph on a slight uphill grade the engine was really quiet, quieter than when going down hill! Oregon has very few roads posted above 55 so I spent hours on hours in 4th gear.
Nanny works! :thumbup: I have the BajaRon sway bar. On curves that are posted at about 35 or higher, nanny kicked in at about 22 mph above the posted speed. On CA SR 3 going north off SR 36 there were a lot of tight curves, some posted as low as 15. I had nanny kicking in on many of those, and even managed to squeal a front tire twice! I would never have ridden my Goldwing around those corners that fast!
So, contrary to all the bad press here about the 2013s, my ride was pretty near perfect.
