SPECTACUALR SPIDERMAN
Sorry, but that isn't the reason they used nitrogen in the airplane tires. Nitrogen, oxygen and the blend of gasses we call air all behave exactly the same way according to Boyle's law. Basically, this law says that pressure is proportional to temperature, assuming the volume is a constant (like in a tire). The pressure will fall the same amount going from a hot to a cold area whether the gas is N2, O2 or air. Furthermore, those who say their tire pressure never changes when they use nitrogen just aren't being picky or observant enough. There is enough difference between summer and winter temperatures to alter the pressure a pound or three regardless of what gas is inside the tire. Nitrogen is used to purge moisture in HVAC systems because it contains practically zero moisture content.
If you want to convince yourself that Boyle's law is really true, then fill your tires with N2 and let them cool over night. Check the pressure. The next morning, get out on the highway and ride for 30 minutes at 60 or 70 to let the tires heat up. Then, immediately check the tire pressure again. I'll bet you anything that you will see an increase in tire pressure of several psi.
it is the moisture content of air that expands with heat, that is why nitrogen is a more stable gas for filling tires. those who
do paintball over the years have probably switched from c02 to nitrogen because it is a dry gas so the paintballs do not
jam up as easy.
