I'm sorry, I read it and it wasn't clear. I took all my panels off to get painted at the paint shop, then I took off my fairing to paint it because it has a mold for single din stereo. I had led lights on my bike, I took them off to replace them because they were old. I tapped into the brake wire because my new lights had a brake wire so when I apply the brakes everything turns red. Next I put my fairing back on the bike and turned the key, the dash didn't light up so I shook the wires behind the Cluster and everything started working but my tail lights, head lights and brake lights. I then unplugged the led lights but nothing changed. I tested the fuses on the right side of the bike and fuses F1 and F2 are reading 3 volts. My old led lights were on F1 but they don't work on F1 because of the voltage so I put them on another constant fuse and they work fine. Also, I took that apart from the front to the back looking for a wire that's shorting, I found nothing touching or unplugged. Please help.
Ps: The added lights do have a turn signal wire and the turn signals work fine with the led lights on both sides. I was looking at my bike this morning and I remembered, I added another antenna to my radio and there was a flat silver wire on the right side that was bolted to the old antenna ground and now it's not connected. Will this affect my lights?
